rear lockers
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Nov 25, 2009.
  1. Nov 25, 2009 at 11:15 AM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey guys I got a 03 taco prerunner v6 3.4.......I have limited slip that comes with the truck is there anyway that I can add the rear diff lockers on my truck
  2. Nov 25, 2009 at 11:16 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    Yea im pretty sure you can. I really dont know much but arb and others sell lockers. or you could just get a whole new axle.
  3. Nov 25, 2009 at 11:23 AM
    Bachenstien
    Bachenstien Well-Known Member
    Andy
    Portland area, oregon
    Tacoma SR5
    3" Fabtech coil overs/rear block, Front and rear diff locked.
    Here is what i did..... I installed a Powertrax easy locker in my rear diff. I love it!!!! Its way cheaper. I paid about 430 Us dollars. All you do is take out your driveline, pull out diff housing, take diff out, pull off cover, and install it. You must have to know a little about difffs to install it but shouldnt be hard to find someone who will do it. You could take it out then take it to a machine shop who will do it professionally.
  4. Nov 25, 2009 at 11:27 AM
    socal19
    California
    Does it matter which on.....I don't know much about diffs I saw on from powertrax and it says 8" sumthing
  5. Nov 25, 2009 at 11:54 AM
    Bachenstien
    Andy
    Tacoma SR5
    yes it matters. I got the wrong part two times in a row because my ring gear is exactly 8 inches. Four wheel parts said otherwise. Call manufactuer and they will tell you exactly what you need.
  6. Nov 25, 2009 at 11:56 AM
    socal19
    California
    So call toyota.........or the locker manufacturer......should it say in our manual
  7. Nov 25, 2009 at 12:01 PM
    Bachenstien
    Andy
    Tacoma SR5
    My friend and I measured it. You could call the toyo manu with Vinn number if you dont want to measure it. The manual is useless
