Rear lockers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MauiJR808, Sep 2, 2020.
  1. Sep 2, 2020 at 10:25 AM
    MauiJR808
    MauiJR808 [OP] Well-Known Member
    Jrey
    Hawaii
    2008 black tacoma 4x4
    Paint black with gold pearl with camper
    So I have a 08 tacoma sr5 been wanting to install a rear lockers. My truck has LSD and its useless offroading. I found a 05 tacoma at the junk that has a E lockers. Would it be possible to take that whole rear axles and wiring swap it on to my truck. Im pretty sure my cousin can figure out the wiring and I can install the rear my self and the guy at the junk said it would bolt right in. Its sounds too easy is there anything u have to do or worry about???
  2. Sep 2, 2020 at 11:05 AM
    MauiJR808
    Jrey
    Hawaii
    Thank you. That truck got in to and accident and it looks like it rolled or flip over. Too much risk and ill take your advice. Ill pass on that project.
    whatstcp likes this.
  3. Sep 2, 2020 at 11:25 AM
    MauiJR808
    Jrey
    Hawaii
    Would you know what gear ratio my truck is. I heard you can find it on the door jam but the letters and numbers doesn't make sense to me. Lol20200901_211838.jpg
    Brie likes this.
  4. Sep 2, 2020 at 11:29 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A04C means you have 3.73 with a limited slip.
    dk_crew, GilbertOz, EdgemanVA and 3 others like this.
  5. Sep 2, 2020 at 11:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you're looking for a budget solution, check out lunchbox lockers. They can be clunky and loud on pavement around turns, but it's just how they're designed and is normal. They're not for everyone, but I love mine. The main benefits are inexpensive, can be installed in a driveway with no special tools, and reliable, meaning no electronics or air hoses to fail.
    https://www.tacomaworld.com/threads...lip-aka-lunchbox-locker-in-my-2nd-gen.561142/
    edit: After a quick search, a lunchbox locker will not work in an LSD carrier. You would have to get a carrier from an open diff, and that would negate the whole "Not needing any special tools". Unless you got a completely assembled 3rd diff from someone.
    Brie and whatstcp like this.
  6. Sep 2, 2020 at 11:47 AM
    MauiJR808
    Jrey
    Hawaii
    Awesome!! I'll look in to it. Thank you!!
  7. Sep 2, 2020 at 11:47 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    See my edit above. I just learned that lunchbox lockers won't work in an LSD carrier.
  8. Sep 2, 2020 at 11:52 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    If you have the 8" diff you only need the 3rd member w/ elocker from the junkyard truck. Even easier. If that's your axle code, A04C, then you have the 8" axle and that's what the elocker will be too.
  9. Sep 2, 2020 at 11:56 AM
    MauiJR808
    Jrey
    Hawaii
    Yes my axles code is AO4C. So everything matches with my truck??
  10. Sep 2, 2020 at 11:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, you cannot just take a 3rd member from an e-locker axle and plop it in the non e-locker axle. There are minor differences between the housings where the diff itself mounts.
  11. Sep 2, 2020 at 12:07 PM
    ShimStack
    Ben
    NC
    Ah yes, this is true. Weren't guys able to make the housing mods or no?
  12. Sep 2, 2020 at 12:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    On the 1st gen tacomas/3rd gen 4runners I've seen it done. I don't know of anyone who's done it on a newer truck though.
  13. Sep 2, 2020 at 12:10 PM
    ShimStack
    Ben
    NC
  14. Sep 2, 2020 at 12:16 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Unfortunately the tags are not accurate. My 2011 Off Road clearly has an E-Locker but the tag says A04C.
    RedWings44 and whatstcp like this.
  15. Sep 2, 2020 at 12:28 PM
    MauiJR808
    Jrey
    Hawaii
    I see. Do you have the trd If so do you know what gear ratio you??
  16. Sep 2, 2020 at 12:30 PM
    MauiJR808
    Jrey
    Hawaii
    So it has the same code but a different gear ratio between the trd with e lockers and my sr5 with LSD.
  17. Sep 2, 2020 at 4:42 PM
    01 dhrracer
    Still Shopping
    GilbertOz likes this.
  18. Sep 2, 2020 at 7:04 PM
    MauiJR808
    Jrey
    Hawaii
    Ok so if I remove my stock rear with no E lockers and swap it out with the 05 tacoma that has E lockers would work with out doing any re gearing because there the same gearing I just have to do all the wiring.
  19. Sep 2, 2020 at 7:22 PM
    MikeDeason
    MikeDeason Well-Known Member
    Love the lsd. Don’t go off road much anymore. I think 90% of truck that have lockers where I’m at would be much better off w/lsd especially Winter driving. Had locker on my Titan and used it about 5 times. Could have achieved same results w/traction ramps.
    preaching over. Lockers probably necessity for some.
  20. Sep 3, 2020 at 7:38 PM
    MauiJR808
    Jrey
    Hawaii
    Thats true in thats case but here in Hawaii we prefer lockers because of lava rocks mud and sand.
    Brie likes this.
