Rear locking diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rmarqu2, May 10, 2010.
  1. May 10, 2010 at 3:52 PM
    rmarqu2
    rmarqu2 [OP] YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    Is it true that all (base 4x4, not TRD models) 2nd gen tacomas have rear locking diff when in 4wd-lo? Heard it from a friend at work so I thought I'd ask the experts on here.
  2. May 10, 2010 at 3:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no. only trd models have the locker. otherwise...it's an open diff.
  3. May 10, 2010 at 3:57 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    damn....... i was almost excited to only have to buy one locker in the future! lol
    Does OX make a cable-drive locker that fits a taco? I don't want to shuck out all that money for a compressor.
  4. May 10, 2010 at 4:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i honestly dont know.....but i do know that the arb air lockers are badass......hard as hell to tear them up.....and they fit/install rather easily from what ive heard.
  5. May 10, 2010 at 4:30 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    yea but pricey... i know that you get what you pay for but that would mean around $1,600- $1,900 after installation. I think i'm just gonna buy an ATV in a year or so....... lol
  6. May 10, 2010 at 4:34 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Why not install yourself ?? Or just get lock right for now, easy install still a locker. Takes two guys around 3 -4 hour to install one. (you should have a friend to hold things down while /bolting/unbolting)
  7. May 10, 2010 at 4:36 PM
    jandrews
    '09 FourDubDee TRD OR
    TRD Offroad is the only package with the locking rear diff and ATRAC. And those two make it a monster, even in stock form.
    Edit: This is 09+ only. Pre-09 still has the locker, but no ATRAC.
  8. May 10, 2010 at 4:37 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
  9. May 10, 2010 at 4:39 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    well me and all my friends are ER nurses. We could probably take apart and put back together a human fairly easily, but i don't know about a differential, that shit's just complicated
  10. May 10, 2010 at 4:40 PM
    jandrews
    Actually, compared to the human body it's pretty simple.
  11. May 10, 2010 at 4:47 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i'm combing the junkyards for a wrecked TRD..
  12. May 10, 2010 at 4:48 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    So what you're saying is that my base '09 4x4 has limited slip but only in 4hi, not 4lo (when you would most likely need to use it). That's crappy.....
    And i'm still under warranty, so i don't wanna be playing with high-risk mods. But that mod does sound like a great one for people trying to make full use of what your taco already has under the hood!
  13. May 10, 2010 at 4:50 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    Hell yea!! I'd probably rip out a supercharger or turbo while i'm at it!
  14. May 10, 2010 at 4:51 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    yup! And i'll find a million dollars AND a supermodel!!!! ;)
  15. May 10, 2010 at 4:52 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
  16. May 10, 2010 at 4:53 PM
    BlueT
    NorthEast
    Lockright installation is quite simple You just have to be careful and tighten all the bolts to specs after word. But otherwise ..
    Follow the write up from here http://www.4x4wire.com/toyota/tech/lockright_locker/
    Its actually very easy there are some things that are no longer applicable like our bearings inside the carrier are fix set so you have to make sure you put spacers on the correct side, which is why you need to mark everything as you are removing.
    It took me Saturday to do it and I had no problems with it or differential . if you scared just buy spare diff use that to install lock right and keep your factory one as spare in case things dont go your way.
    EDIT: If you are nurse you should have no problems. Human body is much more complicated then this. :)
  17. May 10, 2010 at 4:54 PM
    Isthatahemi
    TRD OFF ROAD
    The TRD diffs are weaker, and not worth the hassle, IMO. Guys who use'em, break them.
  18. May 10, 2010 at 4:55 PM
    jandrews
    ...it's better than most 4WD vehicles out there that simply have open diffs no matter what.
    Also, 4lo isn't necessarily when you're most likely to need limited slip. I would tackle sand, snow, and loose dirt in 4hi first before trying 4lo.
  19. May 10, 2010 at 4:55 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    probably could snag a whole rear end for less than like, an arb or somethin, right?
  20. May 10, 2010 at 5:08 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    I'm mostly tackling steep trails, rocks, and whatnot. Mostly stay in 4lo just to keep it safe and slow. I've never had a problem with any obsticle on the trail (just front clearance problems) with my current setup, but i'm ready to start taking on more challenging tasks that i would feel alot better taking on with lockers. And i don't really want to put permanent locks in because this is my primary vehicle and i do use it on the highway.
