Rear long travel = broken e brake fitting....
Discussion in 'Long Travel Suspension' started by IRACE87, Sep 20, 2011.
  1. Sep 20, 2011 at 5:47 PM
    IRACE87
    IRACE87 [OP] Member
    Pat
    Up North
    07 TRD Sport
    Well, I did search but did not found any thread with this particular issue. A few months ago I installed an All-Pro LT kit on my truck with the expedition rear leaf pack with Fox shocks and Timbren bump stops.
    Last week after some good offroading I found that by brakes were braking more than usual and that after backing up and going forward the front brakes would lock up......until I gave enough gas to get going.
    After looking at averything that could cause that problem I found that my parking brake cable had the brackets that is attached to the drums broken. Which could explain my problem since the self brake adjustment is probably all screwed up.
    Now I'm assuming this was caused by the suspension going full travel and having the parking brake cable under tension which cause those cast brackets to break.
    Has anyone had that issue before ???? And how did you fix it.....longer cable or got rid of the cables.......
    Thanks
    Pat
  2. Sep 20, 2011 at 5:55 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Lt guys get rid of the e brake
  3. Sep 21, 2011 at 5:36 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    The expo pack /=/ LT. LT is spring under axle or linked.
    You can get a longer cable or ditch the E-brake.
    One piece of advice, having run that exact same set up in the rear - ditch the Timbrens. They limit up travel way too much. I just ditched mine last week; I bought a simple set of daystar bumpstops and mounted them to the frame instead. I now have twice as much as up travel than I had with the Timbrens and it makes a world of difference.
  4. Sep 21, 2011 at 8:47 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    must have smacked it on something! there are many guys running stock or lt rear on the 2nd gens with no e-brake problems. the length of cable is fine for most the lt kits out there.maybe you had the cable routed wrong? dont know why anyone would want to get rid of the ebrake unless its a full blown race truck .
  5. Sep 21, 2011 at 9:06 AM
    IRACE87
    IRACE87 [OP] Member
    Pat
    Up North
    07 TRD Sport
    The springs are installed in the stock configuration (over the axle).
    Who makes longer cables that fit ?
    Yes I did find that the Timbrens limit up travel quit a lot.........
    Well the cables are still routed in the stock location, I even got rid of the stock bracket that was screwed on the side of the stock springs to pevent the cables for not having enough play........anyway I could not put the stock bracket back on the All-Pro springs.
    No they did not get smacked by looking at them......I should post a pic.
  6. Sep 21, 2011 at 9:11 AM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    interesting.... :popcorn:
  7. Sep 21, 2011 at 11:20 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    yup.
    this is my e-brake
  8. Sep 21, 2011 at 11:37 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    ^ me too!
    harbor freight e-brake
  9. Sep 21, 2011 at 2:29 PM
    IRACE87
    IRACE87 [OP] Member
    Pat
    Up North
    07 TRD Sport
    Well I would have hoped that some instructions about that issue would have been included with the kit............and I'm surprised not to find other post with the same issue.
    You can see on the pic that it broke at the top portion of the bracket.
  10. Sep 21, 2011 at 2:45 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I'm running the same setup as you for the rear (with no bumps for now) and haven't had any problems with the e-brake and mines just hanging there?!:confused:
  11. Sep 21, 2011 at 4:18 PM
    Mxpatriot
    I would bet it snagged on something; as there are a bunch of us running that same set up and no one has had this issue.
  12. Sep 21, 2011 at 7:04 PM
    IRACE87
    IRACE87 [OP] Member
    Pat
    Up North
    07 TRD Sport
    Well both side broke the same way and can't see how and where it would have snagged.........?????
  13. Sep 21, 2011 at 7:30 PM
    Defined
    mike
    southern california
    maybe from just flopping around??possibly getting hung up on something on the frame at different points of travel ? since they are not secured properly.
    did you hit any water at any good speed? ive bent heatshields from hitting water too fast before
  14. Sep 24, 2011 at 1:15 PM
    IRACE87
    IRACE87 [OP] Member
    Pat
    Up North
    07 TRD Sport
    Well....I found the problem.......CORROSION.......Look at the pictures, I removed the cables and I was wondering why the rubber piece was bulged.....I cut it open and found that most of the bracket was turned into white dust except for 2 pieces. (both cables are like that)
    The truck is a 2007 with 45000 miles......never saw anything like that before.....what a piece of junk. I wrongly thought that it was the LT kit because I started having problem not long after installing the kit.......well new cables are probably pretty expensive $$$$$$$.
  15. Sep 24, 2011 at 6:38 PM
    Mxpatriot
    Glad you found the problem.
    It's still not an LT kit.
  16. Sep 25, 2011 at 6:56 PM
    IRACE87
    IRACE87 [OP] Member
    Pat
    Up North
    07 TRD Sport
    Well.....it sure is at least a Longer Travel than stock, and All-Pro do state the following '' Improve your Tacoma's suspension performance and gain lift for tire clearance and long travel with.....''
  17. Sep 26, 2011 at 9:25 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    It says that but you have "The 2005+ Tacoma 3" lift springs". Those are not LT. Below are All Pro long travel leafs. You have a lift, not LT
  18. Sep 26, 2011 at 5:35 PM
    theduck911
    Max
    Locked and Geared!
    Is what it should say.
    With leaf springs (when referring to Tacos) a Long Travel consists of a SUA (Spring-Under Axle) Conversion. Companies such as Defined, Giant, DMZ, & Engage offer these.
    I am running the same setup as you and it no where near a long travel. It has increased uptravel by 1-2" (since I believe this leaf pack is 1" or so taller at the Center pin then stock, not sure) and maybe a few increased inches of flex.
