Rear main oil seal leak at 120k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Nov 6, 2022.
  1. Nov 6, 2022 at 11:14 PM
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Just a data point for others. Has anyone had a similar issue and what was your mileage?
    At almost 120,000 miles, I found oil on my driveway. Looked for a leak and found it at the bell housing. Figured it to be the rear main seal as higher up was dry.
    Due to timing, I had a shop repair it. Cost about $1100 in the Denver area. They confirmed and replaced the seal. Said it was leaking pretty good.
    Will update on shop when I actually get back home and look at it.
    This is the first non warranty/recall-covered maintenance issue I've had with the truck.
  2. Nov 6, 2022 at 11:46 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    07 Double Cab
    My rear main on my 2nd gen started leaking at about 100k miles. Ended up throwing in a new seal during a clutch replacement
    Hooper89 likes this.
  3. Nov 7, 2022 at 4:37 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Rear main seal at that mileage is unusual. Before you pay for that job, check and clean your PCV valve. A plugged PCV will push oil out of seals.
    vanhap, skimkrazy, usmc2msu and 6 others like this.
  4. Nov 7, 2022 at 6:06 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Usually if not a defective manufactured seal that was installed, the engine has been run with excessive rpm much of its life, or your crankshaft has excessive runout.
    mquibble likes this.
  5. Nov 7, 2022 at 7:00 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    So basically all of these trucks trying to stay at the 80mph speed limit on the freeway? :rofl:
  6. Nov 7, 2022 at 7:15 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    If that's the only issue you've had in 120k you are doing well. I'd be keeping an eye on bearings, u joints, differentials, ball joints...
    My work trucks all had/have? leaks at the rear main seal. Super common on chevys. My z28 did too. The only 100% problem free vehicle I owned was a 97 camry. Something about that gold-beige paint color makes them indestructible.
  7. Nov 7, 2022 at 7:29 AM
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    Don't feel bad, if it was a Jeep or a Chevy it would have started leaking at 120 miles
  8. Nov 7, 2022 at 7:34 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If it was a BMW it would have leaked with 1.2 miles on it
  9. Nov 7, 2022 at 7:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    :eek:
    That's a lot of labor! Or high rates. Or both!
  10. Nov 7, 2022 at 7:42 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Bilstein 8112+650lb coils, 8100+Deaver Stage II leaf pack, SPC UCA, DuroBumps, Mobtown 0* sliders W/fill plates, Mobtown Recovery Bar, Radium PVC & CCV Dual Oil Separator Catch Can System, Snugtop Hiliner Sport, ATH bed Stiffeners (cuz bottle openers!) and front corner tie down, Badger plates for Firestone airbag + Relentless U-bolt flip + Daystar cradles, TRD Pro shift knob, TRD Exhaust, HPS Silicone intake tube, Green Filter, TRD Intake Air Accelerator, 265-70-17 Toyo Open Country ATIII on TRD 17"Rockwarrior Cold Forged wheels, TRD alloy front skid, RCI Aluminum transmission & transfer case skids. Much Meso awesomeness, FreshMexicanTaco TacoGarage Camera Controller + DDM, WarFab Sheridan hitch skid, Rago LCA steel skids + lower rear shock guards, ScanGauge II, FN Koning Countersteer 16" spare, OEM T4R 90105-14104 coilover lower mounting eye bolts
  11. Nov 7, 2022 at 7:48 AM
    BillyE
    BillyE Well-Known Member
    What oil do you use?
  12. Nov 9, 2022 at 4:01 PM
    Woodrow F Call
    Colorful Colorado
    Independent..... I got several quotes.
    Bbmaddox89 and eurowner[QUOTED] like this.
  13. Nov 9, 2022 at 4:02 PM
    Woodrow F Call
    Colorful Colorado
    Sorry for the late reply..... working a lot right now.
  14. Nov 9, 2022 at 6:19 PM
    Woodrow F Call
    Colorful Colorado
    Mobil 0w-20
  15. Nov 9, 2022 at 6:23 PM
    jaxyaks
    jaxyaks Well-Known Member
    2016 Black TRD Off Road
    Thats a bummer and kind of unexpected.
    What oil change interval do you normally do?
  16. Nov 9, 2022 at 6:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    He told me every 259 miles...
  17. Nov 9, 2022 at 6:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Why so slow? Do we need to run faster to maintain seal longevity?
  18. Nov 9, 2022 at 6:33 PM
    jaxyaks
    Welp, that will cause it every time, you gotta give the gasket a little more soak time.
    hiPSI[QUOTED] likes this.
  19. Nov 9, 2022 at 6:34 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Wait...maybe he told me every 29589 miles...
  20. Nov 9, 2022 at 6:35 PM
    jaxyaks
    That'll cause it too, you know the mobil 1 is only good for 20K
