Rear main seal 2001 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by TylerE, Apr 8, 2022.
  1. Apr 8, 2022 at 8:51 PM
    TylerE
    TylerE [OP] Member
    Tyler
    2001 Tacoma Limited 450k
    Basic stock.
    New to posting. Sorry if repeat. Where transmission meets engine. Oil leak. I guess that’s rear main seal. Any tips, advice, cost analysis. Appreciate any direction.
  2. Apr 8, 2022 at 8:55 PM
    TylerE
    TylerE [OP] Member
    Tyler
    Basic stock.
    That is easily the funniest misspelling of mechanic I’ve ever seen. Thank you. And ideally myself.
    High Noon likes this.
  3. Apr 8, 2022 at 9:11 PM
    TylerE
    TylerE [OP] Member
    Tyler
    Basic stock.
    Automatic. Do I need to remove driveshaft and transfer case as well?
  4. Apr 8, 2022 at 9:19 PM
    TylerE
    TylerE [OP] Member
    Tyler
    Basic stock.
    oh I watch him all the time. Him
    And Scotty Kilmer. Thanks
  5. Apr 8, 2022 at 9:27 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Apr 8, 2022 at 9:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Up to you but the trans has to come out unless you want to do the engine.
    Make sure your valve covers aren't the real leak.
  7. Apr 9, 2022 at 5:47 AM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    X2 on valve covers. I bought my 01 last June with what I thought was a badly leaking rear main. Even bought it with the leak projecting to spend $800 for the dealer to fix it. Most of the oil accumulated right where you are speaking of. Ended up changing the valve cover seals and there isn’t a drip of oil anymore.
    I highly suggest checking that before going into the rear main replacement, valve cover leaks are notoriously deceptive.
  8. Apr 10, 2022 at 7:04 PM
    TylerE
    TylerE [OP] Member
    Tyler
    Basic stock.
    Perfect. Thanks for heads up, I’ll do just that.
    ijm01PR[QUOTED] likes this.
  9. Apr 10, 2022 at 7:38 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  10. Apr 10, 2022 at 7:41 PM
    ijm01PR
    Alex
    Indiana
    Good luck! Let us know how it goes
  11. Apr 11, 2022 at 9:48 AM
    Rags
    Rags Active Member
    Dan
    AZ
    04 Gold PreRunner 2WD 3.4
    Same here. Saw dripping from main seal, but my mechanic said it was coming from rear cam plugs and oil cooler assembly.
  12. Apr 11, 2022 at 10:24 AM
    alexh
    alexh Well-Known Member
    1998 TRD
    We should make a sticky on chasing oil leaks, I bought my truck new, replaced valve cover gaskets at about 8 years, then had to do it again because I did not know about the cam plugs (not in that section of manual). Then oil cooler, then oil filler cap, then front seal. Also, oil dipstick oring. Mt truck was never oil free until I did all of these within a few years of each other. Of course the front crank seal would only be done as part of timing belt. The rear seal has a spring to maintain contact with crank so probably lasts longer than most seals.
    Almost seems like no matter where the leak is, the oil is blown back onto the rear and ends up on steering rack and even on the trans.
    Definitely do these as much as possible all at once because likely they are are all leaking to some extent if not done in last 10 years.
    ijm01PR and JustADriver like this.
  13. Apr 13, 2022 at 11:45 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    Yea first check to make sure the valve covers are not leaking or anything around there.
    If it is the rear main seal i would suggest you remove the transfer case. IMO it makes revoming and reinstalling the transmission much easier. Have a transmission jack will also make things way easier.
    good luck
  14. Apr 14, 2022 at 8:05 AM
    Indyteecee
    Indyteecee bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
  15. Apr 14, 2022 at 1:00 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I would say drop the transmission and tcase as one unit.
