Rear main seal leak quit leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by BackroadBetty, Jul 11, 2017.
  1. Jul 11, 2017 at 6:48 AM
    BackroadBetty
    BackroadBetty [OP] New Member
    1995 Tacoma 4X4 V6 automatic
    I've had a rear main seal leak since 2007 when I bought the truck. I have done pretty regular oil changes and never done anything about the leak. At times it has been pretty bad, adding oil every week or two. After the last oil change, it seems to have quit leaking. Going to get it changed by my mechanic today. What does it mean that it has quit leaking? Is there a way to flush it out and do I need to?
  2. Jul 11, 2017 at 7:17 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    What oil weight do you use? Maybe you/your mechanic put a slightly thicker oil in by mistake and 'fixed' it.
  3. Jul 11, 2017 at 7:26 AM
    NM Lance
    NM Lance Well-Known Member
    DO NOT flush it! I can almost guarantee the leak will come back worse than it was. All you can really do is live with it if it is not horrible, or get the rear main replaced. Since you have an automatic, you don't have to worry about oil getting on your clutch components causing them to slip. I would leave it, if you can live with it.
