Rear main seal leak. :(
Discussion in '1st Gen. Tacomas (1995-2004)' started by SRQ TACO, Mar 7, 2011.
  1. Mar 7, 2011 at 2:02 AM
    SRQ TACO
    SRQ TACO [OP] Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    My rear main seal is leaking. Weird though cause my truck only has 92000 Miles on it. How should I go about replacing this. Is it hard? Should I swap a 5 speed in since I'm probably gonna have to drop the tranny?
  2. Mar 7, 2011 at 2:36 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Kyb Shocks... for now
    from toyota FSM:
    4. REPLACE CRANKSHAFT REAR OIL SEAL
    HINT:
    There are 2 methods ((a) and (b)) to replace the oil seal.
    (a) If rear oil seal retainer is removed from cylinder block:
    (1) Using a screwdriver and a hammer, tap out the oil
    seal.
    (2) Using SST and a hammer, tap in a new oil seal until
    its surface is flush with the oil seal retainer edge.
    SST 09223–15030, 09950–70010 (09951–07150)
    (3) Apply MP grease to the oil seal lip.
    (b) If rear oil seal retainer is installed to cylinder block:
    (1) Using a knife, cut off the oil seal lip.
    (2) Using a screwdriver, pry out the oil seal.
    NOTICE:
    Be careful not to damage the crankshaft. Tape the screwdriver
    tip.
    (3) Apply MP grease to a new oil seal lip.
  3. Mar 7, 2011 at 6:28 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    edited because
  4. Mar 11, 2011 at 8:47 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Thanks Branden sorry I didnt respond I forgot about this thread. And I do really want to put a 5 speed in.
  5. Mar 11, 2011 at 9:04 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    its not cost effective just for a rear main seal tbh. now if that trans breaks, i'd do it for sure. you need a flywheel, bell housing, clutch slave cylinder, clutch pedal assembly, you'd have to cut a hole in your cab, figure out wtf to do with the column shift.. its just a list of bullshit
  6. Mar 12, 2011 at 2:10 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    But the gasket is like 15 bucks right? Just gotta unbolt the tranny pull it apart a little and pull out the gasket and install the new one.
  7. Mar 12, 2011 at 2:18 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    showing 18.99 at autozone which is a felpro rear seal as well as the gasket for the rear seal housing.
    well its a little more involved then that unfortunately. You have pull the trans and remove the flexplate (the flywheel of an automatic). This will reveal the RMS and it's housing.
    Out of the 2 available options, i would remove the housing so as not to damage the crank, an 18.99 job could turn into a totalled engine job real fast if you fubar the crank
  8. Mar 28, 2011 at 5:50 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    True. Ok well atleast the parts are cheap. Should I drain the transmission when I'm under there aswell?
  9. May 19, 2011 at 9:14 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Note to you guys I recently purchased Bars Rear main seal leak stop and have been waiting 2 months (2000 Miles) for the engine to get a quart low (its only dropped a 1/4 of a quart in two months) so I think I have a very very tiny leak and my dads mechanic said this stuff should stop it if its that small of a leak.
  10. May 19, 2011 at 9:18 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Also my last oil changes were done with different oils. Toyota used mobile and I used Pennzoil. The truck has always had Castrol GTX in it its whole life. Should I go back to the Castrol and add that quart of bars?
  11. May 19, 2011 at 9:21 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    you can switch back to castrol but it really shouldn't matter.
  12. May 20, 2011 at 10:00 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Well idk why its leaking at 95000 miles.
