Rear Main Seal Oil Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by s0uth3rn_tacoma, Aug 23, 2024.
  1. Aug 23, 2024 at 8:14 AM
    s0uth3rn_tacoma
    s0uth3rn_tacoma [OP] New Member
    Hello! I recently bought a 2012 Toyota Tacoma with 114K miles on it. Before I bought it, i got a PPI and it showed VERY early signs of a leak from the rear main seal. I drove it yesterday and it dripped a small amount of oil. How common are these issues with tacomas?
    SethM likes this.
  2. Aug 23, 2024 at 8:23 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Don't know how common, but it does happen, Just luck of the draw.
    s0uth3rn_tacoma[OP] likes this.
  3. Aug 23, 2024 at 8:25 AM
    s0uth3rn_tacoma
    Yeah, its only like $1200-$1500 to fix, so not BRUTUAL to break the bank.
  4. Aug 23, 2024 at 8:26 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Not very common.
    But as stated, it happens.
    The timing cover, valve covers, and transmission output shaft seals usually leak first.
    Canadian Caber likes this.
  5. Aug 23, 2024 at 9:08 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    I do alot of river crossings, and mudding, and sand every time after Azuza OHV RMS leaks. A bottle of AT 205 and the seal will swell up again. Only a temporary solution.
    1 Limited Toyota likes this.
  6. Aug 23, 2024 at 9:10 AM
    SethM
    Seth
    Los Angeles ca
    Drop the tranny and fix for cost of seal about $40 and a Saturday,Sunday of work
  7. Aug 24, 2024 at 10:27 PM
    TacoTuesday1
    SD CA
    How common is a rear main leak? It happens. Not a big deal.
    10/100 is generally considered end of life for a wearable vehicle component.
    PCV applies vacuum to crankcase. PCV valve clogs. Easier and cheaper to start with that and re-evaluate.
    It's $40.
  8. Sep 3, 2024 at 9:46 AM
    s0uth3rn_tacoma
    so it turns out the leak was coming from the front differential where the CV Axle goes in - it needed a new bearing and seal. $350 fix.
