Rear main seal worth replacing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Indyteecee, Jan 11, 2018.
  1. Jan 11, 2018 at 6:49 PM
    Indy
    Indy Master of all I survey.
    Rear Mai shouldn't be getting oil on your shock.
  2. Jan 11, 2018 at 8:36 PM
    Indyteecee
    Indyteecee [OP] bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
    Quite. I was confused about that. What do you think that could be?
  3. Jan 11, 2018 at 8:41 PM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    Mine looked the same. Around 230k. It’s was the valve covers leaking down and it looked like it was the rear main sseal
    cruxofthebisquit likes this.
  4. Jan 11, 2018 at 8:43 PM
    Indy
    Something leaking above your shock :)
    Wise ass answer but without being able to look myself its the only one I'm confident in giving. Just because you have oil on the main doesn't mean that's where it's leaking. That's just the lowest part of the bellhousing so any leaks above will show up there. You have to find the highest point that has a leak and work your way down.
    And just because you find a leak higher up doesn't mean your main ISN'T leaking as well. Leaks tend to happen in bunches. If 1 seal is x years old and fails, all the other seals are just as old as the failed one. Same reason you replace both headlights at once even if 1 still works.
    Really clean your engine, it will make finding a leaks source a lot easier.
  5. Jan 11, 2018 at 9:05 PM
    Indyteecee
    Wyatt
    Utah
    So what are all the points I need to check for leaks? Just rear main and valve cover gaskets?
  6. Jan 12, 2018 at 7:33 AM
    WhiteTaco98
    WhiteTaco98 Well-Known Member
    98 SR5 4x4
    I thought mine was leaking as well but it turned out to be the passenger side valve cover. Oil was finding its way down along the engine, across the front face of the transmission and onto the steering rack. After wiping everything down and watching it daily, it was obvious it was coming from the valve cover.
    4drtaco03 likes this.
  7. Jan 12, 2018 at 4:02 PM
    Longhorn71
    Longhorn71 Member
    Geno
    Calgary, Alberta
    1999 black prerunner xtracab
  8. Jan 12, 2018 at 4:09 PM
    Longhorn71
    Longhorn71 Member
    Geno
    Calgary, Alberta
    Saw your concern over a rear main seal leak, I purchased a product called " AT-205 RE-SEAL" for my leaking 2.7 litre engine. I was quite surprised to see that it did in fact seal up my engine leak that was 2 weeks ago. Lots of youtube info on this stuff and of course literature. I have no vested interest in this product. I am very happy with the results. My 2 cents worth.
    Yota4Life89 likes this.
  9. Jan 12, 2018 at 4:16 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I had the dealer charge out a leaky RMS on my '01 2.7l (225K) when they did the frame replacement. Under the circumstances, it was easy as they had the engine out, and I only paid a minimal amount for the addition labor/parts.
    It drives me crazy when I have an oil leak, so there was no question about either me fixing it, or in this case, the dealer. The valve cover gaskets also seem to be a common leak point that is worth checking out. Might catch a break there if they are the source.
  10. Jan 12, 2018 at 7:16 PM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Yup. Highly doubt any and play.
    Luv my yota likes this.
  11. Jan 12, 2018 at 10:57 PM
    Indyteecee
    Wyatt
    Utah
    Auto. Front seal isn't leaking at all. I agree with you about the crank play thing too. When the first mechanic told me that the crank could have play, I was thinking to myself "ok he really doesn't know these trucks", but then when a second mechanic told me the same thing, I started getting scared. Still it's hard for me to believe that this motor would develop that bad of play to where the rear main won't seal properly at only 227k. I just don't think that's the case.
  12. Jan 13, 2018 at 7:26 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Probably valve covers and cam plugs leaking. What mine looked like. There was oil everywhere!!!
  13. Jan 13, 2018 at 7:37 AM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    OP, please check the valve covers first. Take your clean hand and feel around gently on the rear of each head. Do you have oil on your hands? Report back here.
  14. Jan 13, 2018 at 11:29 AM
    Indyteecee
    Wyatt
    Utah
    Just checked. Back and sides of the engine are clean. It's not valve cover unfortunately...
  15. Jan 13, 2018 at 1:29 PM
    #35
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    How about checking then just barely under the heads with youre hands, if you havent yet.
  16. Jan 15, 2018 at 4:30 AM
    #36
    Russianman92
    Dunwoody GA
    Ok a lot of people telling you to do a lot of stuff. Let's summarize:
    1) Clean Everything with brake cleaner/rags. Get all the oil off. Make as though youre gonna eat off that thing.
    2) Drive it/run it for 1 day.
    3) Start from the top of the engine (valve covers etc) and work your way down. (back of the heads down to the bell housing etc) Since you cleaned everything any oil leaks will be very easily visible.
    4) Once you found the source, or area, it should be fairly simple to know what to replace. If you need help use a parts diagram of the area to eliminate what you know is not leaking.
    5) Assess the cost and or skill level of doing it yourself vs shop doing it.
    Bottom line:
    This method will pinpoint exactly where the issue is and how much it should cost. I think we are all just pointing at stuff where it could be leaking since we can't be there to look.
  17. Jan 15, 2018 at 5:58 AM
    #37
    tony2018
    tony2018 Well-Known Member
    How about cleaning up all signs of oil leaks, refill oil to proper level and every day you look around the engine to see where its leaking. Rear main seal would not splash oil over your front shocks. It would be splashing it all over your flex plate, transmission cover and lower transmission.
  18. Jan 16, 2018 at 4:21 AM
    #38
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    Subscribed.
  19. Jan 16, 2018 at 12:35 PM
    #39
    Indyteecee
    Wyatt
    Utah
    Cleaned it all off Sunday and watched it all yesterday. I'm %99.99 sure it's rear main. Going to go to a friend of mine today who owns a shop that does great work and see what he thinks the best option is.
    It's also getting worse by the day. Puddles getting bigger and bigger every morning...
    Russianman92 likes this.
  20. Jan 16, 2018 at 1:00 PM
    #40
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    It is absolutely worth replacing. While you're at it, replace the front main seal, do the valve covers, coolant hoses, thermostat, radiator cap, PCV and a good thorough inspection by someone you trust. Give her the love she's given you, and you can expect many many more years of devoted service. :thumbsup:
    BassAckwards and Russianman92 like this.
