rear o2 sensor - DONE!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowyer2002, Feb 26, 2011.
  1. Mar 3, 2011 at 8:45 AM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    From what I understand about it, it is either working or not, atleast the style that is on our trucks.
    I just had to change the primary O2 on mine. You can run a test on the sensor with a multimeter. Take an ohm reading between the two black wires. Bank 1 sensor 1 on a 1gen should read between 0.8 and 1.4 ohms. My replacement one read 1.2 and the old one that was throwing the code had no continuity between them. Just a quick tip to pass on.
    Hamer95USA likes this.
  2. Mar 3, 2011 at 8:48 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    good idea, where's the connector for the primary? is it easily enough to find when i crawl under the truck or is the connector hidden some where?
    thanks
  3. Mar 3, 2011 at 9:01 AM
    shocker01
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    The wires that are coming off of the sensor itself is where I took the readings. Just unplug the sensor and test it at the connector.
  4. Mar 3, 2011 at 9:36 AM
    bowyer2002
    bowyer2002 [OP] always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    AMAZON.COM - good luck!
  5. Jun 20, 2011 at 9:17 AM
    s1deout
    s1deout Active Member
    PGH
    1996 Tacoma Regular LX, 2.7, 5 Speed
    Just did this to mine this weekend. Rear O2 sensor was throwing a CEL and the nuts were a pain to get off.
    Good advice: Spray with liquid wrench or wd40 for a couple days before attempting.
    Question: Where can I get one of those o2 sensor shields?
  6. Jun 20, 2011 at 11:19 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Rust is definitely a pain in the ass. On my brother's 97 4runner it threw a CEL and it was the rear o2 sensor. I crawled under the 4runner to see how hard it would be to change. Underneath the 4runner I found the o2 sensor just dangling there hanging by the wires, the bolts completely rusted through letting the o2 sensor come out :eek:
  7. Jan 12, 2012 at 1:19 AM
    JT1521
    JT1521 Well-Known Member
    I need to replace the Downstream Oxygen Sensor bank 1 sensor 2 on my 2003 Toyota Tacoma 4WD as well. I crawled under the truck and saw that heatshield blocking the view of the sensor. Is there noway to take that shield off without cutting it? That seems kind of stupid that they would make them that way knowing that at some point the sensor will have to be replaced. There has to be a way to take it off and put it back on.
  8. Jan 12, 2012 at 2:23 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    nice write up
  9. Jan 12, 2012 at 5:56 AM
    bowyer2002
    NE Missouri
    If you only cut it enough to bend it out of the way and not totally off, you can reinstall it and bend the shield back into it's original position. (see the 3rd picture at the beginning of this post) This is what I did instead of an expanded metal 'one off' shield design, I got lazy.
  10. Jan 12, 2012 at 12:54 PM
    JT1521
    If that is what you did then that picture looks confusing. lol Picture 3 looks like you completely cut the shield off. Then you took the left side of the shield and it is just hanging from the right side.
  11. Jan 14, 2012 at 9:50 AM
    JT1521
    A guy at my mom's work who is also a mechanic on the weekends told her would do it. I will buy the part and let him install it. He told her its easy and only a 10 minute job. I laughed at that. You really have no idea how long something is gonna take especially with rust and corrosion. Maybe it will take him 10 minutes to do but I highly doubt it would have only taken me that long. lol Before I order the part. Denso Part # 2344189 is a perfect fit correct? It says OE next to it. However, it does not say OE Direct Fit. Should I save 25 bucks and go with the OE one or get the OE Direct Fit? Stupid questions I know.
  12. Jan 19, 2012 at 4:13 PM
    JT1521
    Anyone know if the replacement nuts M8 X 1.25 13mm are the same for a 2003 Tacoma? Are they a lock nut or just a regular hex nut? Just curious. Thanks.
  13. Jan 19, 2012 at 5:53 PM
    ruler1
    ruler1 stump thumper
    palmetto fl
    97 2.7 4x4 5speed
    header, k&n intake, ome coils, springs and struts,diff drop, Urd simulator, dynomax exhaust, slotted roters, bpv relocater
    I just ordered two from rockauto.com. Shipped it was 125 bucks and much much cheaper than local parts stores. I will let you know how the install goes.
  14. Jan 24, 2012 at 5:28 PM
    bowyer2002
    NE Missouri
    I just put regular nuts on mine, along with some anti-sieze compound, just in case.
  15. Mar 6, 2012 at 3:10 PM
    #35
    Ishter
    Ishter Member
    Thread is only a little old at this point but, question:
    The bolts holding my rear o2 sensor have no nuts at all. Pulled out of a traffic circle and exhaust gets real loud and sounds like crap. A little looking around finds the sensor hanging loose next to the exhaust. Both bolts are completely corroded with no signs of any nuts working themselves of recently. Is there a preferred method to clean up the studs to accept new nuts or completely replace studs?
  16. Mar 8, 2012 at 6:35 PM
    #36
    JT1521
    Completely replace the studs. I had to on mine.
  17. Mar 9, 2012 at 2:16 AM
    #37
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I did this operation a couple of months back. Ordered both front and rear for my '03 from RockAuto.
    Here in Chicago dealing with the typical rust issues...front one was easy enough to do myself. The rear was a whole different story. After an hour or so of trying to dick around with it...ended up taking it to a muffler shop and paid them $40 cash to install it.
    Money well spent.
  18. Mar 10, 2012 at 4:02 AM
    #38
    Ishter
    Ishter Member
    I used hose clamps. That sucker ain't moving now.
  19. May 3, 2012 at 7:26 PM
    #39
    takaya49
    takaya49 Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    Where did you order yours?
  20. May 3, 2012 at 11:29 PM
    #40
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    #40
