Rear o2 sensor shield replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by thoth, Jul 24, 2017.
  1. Jul 24, 2017 at 11:08 AM
    thoth
    thoth [OP] Well-Known Member
    Culper
    2002 Tacoma SR5 3.4L V6 PreRunner
    Yo, new member here. LOVE THIS FORUM! Its helped me with all my newbie mechanic needs for servicing my truck so far! I just did my first valve cover resealing a few weekends ago and that was super fun.
    So, I had to remove my rear downstream o2 sensor shield in order to get access to the nuts of the o2 sensor and in the process I destroyed the shield. sigh. I thought i was rounding off the nuts so in a desperate attempt I decided i just had to forcefully remove the shield out of the way. Once I did this though i realized the nuts were not rounding off.. they were just ... loosening really easily! UGH. whats done is done though.
    My question is, is the shield a requirement? Like, do I need to work on getting a replacement shield installed or no? If so, does anyone know what the best course of action would be? I know a pick'n'pull place would be a start but looking at online inventories for local places i never see any tacoma's heh. I was hoping someone had a good idea for off the shelf remediation. Some ideas i had were having something welded together but im not really familiar with how all that works as far as having something designed and fitted for what i need. Does anyone happen to maybe possibly have an extra shield available?(long shot i know).
    (I dont off road, the truck will likely only see dirt roads at most if ever. its meant for city driving and it never rains here in AZ).
    Kenny421 likes this.
  2. Jul 24, 2017 at 11:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am not sure what your talking about .
    I can only guess one of the heat shields for the exhaust which seem to get removed and never put back on.
    pictures would be a big help
  3. Jul 24, 2017 at 11:17 AM
    thoth
    Culper
    TylerE and Kenny421 like this.
  4. Jul 24, 2017 at 11:23 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    My truck doesn't have a shield but I wouldn't worry about it. Long as the sensor is working and the wires are secured.
  5. Jul 24, 2017 at 11:24 AM
    thoth
    Culper
    ok cool thanks
  6. Jul 24, 2017 at 11:27 AM
    austinsdad99
    1999 prerunner 3.4
    Not a problem man. Welcome to the forums, excellent info here!
  7. Jul 24, 2017 at 11:30 AM
    thoth
    Culper
    Thanks dude, and ya lots of great info. I pretty much know that I can search juuuust about anything and ill see a google hit for "tacoma world" and 99% of the time is someone having the EXACT situation as me and a ton of cool peeps responding with very useful info. I come from the IT field and its not usually as straight forward as working on trucks has been :)
    TylerE and Dalandser like this.
  8. Jul 24, 2017 at 11:32 AM
    austinsdad99
    1999 prerunner 3.4
    I'm fairly new here myself. Couple months but found lots of useful info.
  9. Jul 24, 2017 at 11:37 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Mine was long gone till I bought the truck .
    Only if the heat above the Cat bothers you would I even think of replacing it
  10. Jul 24, 2017 at 11:46 AM
    thoth
    Culper
    Ya my main concern was that A) it was factory installed for a reason likely and B) that it was mostly for keeping the sensor clean from debris.
    Now that i think about it though, i still have the bottom plate portion of the shield so im thinking maybe i can have someone weld a piece of sheet metal to it and then id be back in biz. but it sounds like its not a huge issue either way.
  11. Jul 24, 2017 at 11:59 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    The prior owner of my truck trashed it long before I bought it. Actually, the last two Tacomas I owned were missing this. It was on my 1997 and 2000 models though, and I had no problem replacing the O2 sensors on either without cutting it off, or whatever it is some mechanics do to it. But the '03 is fine without it, and I can sleep at night with no problem.
    Boatbldr likes this.
  12. Jul 24, 2017 at 12:19 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    I destroyed mine too. Guess like me you will need to avoid driving throuogh heavy brush unless you want to drop $80 for a new one.
  13. Jul 24, 2017 at 12:22 PM
    thoth
    Culper
    Is there even a part number for the part?
  14. Jul 24, 2017 at 12:37 PM
    toyotamd
    toyotamd Well-Known Member
    Arizona
    2002 Xtra Cab V6 auto TRD
    mine doesn't have the O2 sensor cover either. i think you'll be fine without it.
  15. Dec 1, 2017 at 3:27 PM
    Kenny421
    Kenny421 New Member
    Kenny
    2001 tacoma
    Im getting frustrated with that shield . Can anyone tell me what size nut is on it.? I can see enough and its slightly rusty . Im just trying not to destrsy the shield.
  16. Dec 13, 2017 at 4:51 PM
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    How did you get around the metal piece to replace the sensor?
  17. Dec 13, 2017 at 10:32 PM
    ghs57
    Chops
    Catskill Mts. NY
    Boy, that was a while ago. I do remember reading at the time that many did cut it off. But I also remember looking at it and seeing that there was enough room to get at it, and gave it a try. I'm too stubborn to give up on an idea once I start. I don't remember the exact method I used, but I probably tried a number of tools until one worked. Afterwards, I thought cutting the shield was an extreme measure not necessary. This was ten years ago.
  18. Dec 2, 2018 at 1:54 PM
    KLD
    KLD New Member
    2003 Tacoma 4x4
    I am trying to replace my O2 sensor on my 2003 Tacoma and the nuts are stripped so I am probably going to have to cut off the heat shield to get to them. Sounds like I may not need to replace it but did anyone ever find a part number for it or a place to obtain one?
  19. Dec 2, 2018 at 4:36 PM
    Garwood
    Garwood Well-Known Member
    Pensacola, FL
    2002 TRDOR Xtra Cab 5spd MT
    It's 89437-60030.
    TylerE likes this.
  20. Apr 10, 2022 at 7:01 PM
    TylerE
    TylerE Member
    Tyler
    2001 Tacoma Limited 450k
    Basic stock.
    Exactly what I was looking for! Thanks.
    Garwood likes this.
