Rear of bed hookups - suggestions please
Discussion in '1st Gen. Tacomas (1995-2004)' started by slodoug, Dec 22, 2020.
  1. Dec 22, 2020 at 4:52 PM
    slodoug
    slodoug [OP] Well-Known Member
    So i have an empty (dummy) switch on my dash that i'd like to wire to a rear panel of some kind that has some of/the following:
    • USB charging ports
    • Trailer plug
    • 12v socket
    • LED light for inside the camper shell
    Currently, I have a mass of wires running back for:
    • rearview mirror dash cam rear camera (always on)
    • Stereo based reverse-only reverse cam
    • In-bumper backup sensors
    • camper shell 3rd brake light led wire running to led taillights.
    Any ideas on if something exists already or do i need to break out the dremel and do a custom box? Thanks.
  2. Dec 22, 2020 at 5:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    You won't need to run a 3rd brake light wire. Use the one behind taillight driver side and go up and out under bedrail at rear.
  3. Dec 22, 2020 at 5:17 PM
    slodoug
    yes, i know, my 3rd brakelight already feeds off the taillight, i was just mentioning it in the mass of wires
  4. Dec 22, 2020 at 5:33 PM
    Five
    Five Well-Known Member
    Could run a thick guage cable directly from battery terminal to the back. connect that to a relay. Then run an ignition switched wire to the relay. Relay feeds to a fuse box. 2nd fuse box for an always hot connection.
  5. Dec 22, 2020 at 5:34 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    There was a guy on here that was going to make some panels but not sure he ever got going on that. On my 96 that I used to have, I put a piece of aluminum extrusion under the bed rail and had switches for the back worklights, etc in there, as well as 2x 12V power outlets. Need to do something like that with my 99 but haven't gotten around to it. Check out Blue Sea Systems as they make these kind of panels for boats, etc that are integrated with a small fuse box/breaker panel so you can just run a big wire back there to power everything.
    slodoug[OP] likes this.
  6. Dec 22, 2020 at 7:16 PM
    slodoug
  7. Dec 22, 2020 at 9:39 PM
    slodoug
  8. Dec 27, 2020 at 12:42 PM
    slodoug
    so I got it and want to run a 10a wire from the battery, 13ft down to the end of the bed. Figure i'll need 10awg wire. Should I wire it direct (it has a 10a fuse in-line) , or use a spare slot in my engine fuse block?
  9. Dec 27, 2020 at 1:59 PM
    slodoug
    is it just me or do they not make a piggyback fuse holder with a 10 gauge wire?
  10. Dec 27, 2020 at 2:11 PM
    Black DOG Lila
    Virginia
    Last thing I wired with 10ga. Was an Anchor windlass and it took a 50 amp 12V. Breaker.
    Search.bumper winch wiring.
  11. Dec 27, 2020 at 2:24 PM
    slodoug
    the only reason i want to use 10 gauge wire is because of the length from the source. i doubt anything I plug into the USB or cig socket will draw that much amps. But i know i shouldn't connect a 10 awg wire to a 16 awg piggyback wire.
  12. Dec 27, 2020 at 2:50 PM
    Black DOG Lila
    Virginia
    The drop in voltage over the distance from battery to tailgate is insignificant.
    10ga. Is used in high amperage draws in both AC and DC.
  13. Dec 27, 2020 at 7:56 PM
    slodoug
    I think i'm going to expand things a little. I'll run the 10a wire direct but put a 4 way fuse block at the end.
    1. will be that panel
    2. will be the led lights for the shell
    3. will be a port for a solar panel trickle charger I have.
    4. undecided.
    Just need to decide if I want a positive only block or one with a ground on it.
  14. Dec 27, 2020 at 8:12 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
  15. Jan 6, 2021 at 6:40 PM
    slodoug
    is there any dedicated chassis ground after the extra cab ends? Seems like all the ground bolts are in cab at the furthest (from engine). I guess i'll run a ground from the cab too.
  16. Jan 6, 2021 at 6:48 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    I’m 90% sure there is not but I’d have to check the ground diagram which I don’t have with me at the moment. They like to put them inside to stay out of water/dirt so that rules out most of the bed. For testing you can make one on the bed rail, or run a long wire back from the battery
  17. Jan 6, 2021 at 8:51 PM
    slodoug
    thats what i though, the ones under the kick panel passenger side are clean so i think i'll run it from there. I'm going battery to 30a breaker, to 40a relay, back to the bed.
  18. Jan 6, 2021 at 8:52 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It might be easier to just run a ground all the way to the battery instead of having to get it into the cab.
  19. Jan 6, 2021 at 8:59 PM
    slodoug
    maybe, but i have 25ft of 10awg wire, and its 15ft from battery to passenger side and down, and 10 more from cab to bed. The drivers side is a shorter run but more crowded under the hood. Plus the module i use for my rear backup sensors is on the drivers side in the camper shell but the other side is open and has more room for the various panels.
    0xDEADBEEF[QUOTED] likes this.
  20. Jan 7, 2021 at 11:09 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
