Rear OME EL095R-P + OME extra leaf = OME Heavy Springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4wdExplorer, Sep 27, 2018.
  1. Sep 27, 2018 at 9:10 AM
    4wdExplorer
    4wdExplorer [OP] Well-Known Member
    Orange County, CA
    I have a question about the rear suspension setup on my 2015 Tacoma 4x4 double cab SB.
    I want to purchase the OME EL095R-P springs that is good for a medium load no bumper etc.
    Next year I will get a dual swing high clearance rear bumper. Will adding the EL46XK-P add a leaf will this make the OME springs be the heavy 660lb load springs??? Or do I need to buy new springs when adding a rear bumper?
    Seen here. In other words:
    EL095R-P + EL46XL-P (OME Extra Leaf) = EL096R-P (660lb leaf)??
  2. Sep 27, 2018 at 10:04 AM
    4wdExplorer
    Orange County, CA
  3. Sep 27, 2018 at 10:14 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Yes your correct the aal will make it the HDs.
    lynyrd3 likes this.
  4. Sep 27, 2018 at 10:22 AM
    4wdExplorer
    Orange County, CA
    Awesome, that is good news. Thank you. That means I do not need to purchase a new set of leafs just an OME add a leaf.
  5. Sep 27, 2018 at 10:35 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Yep a huge savings for ya. Can’t wait to see the bumper
  6. Sep 27, 2018 at 10:38 AM
    doorsidedown
    doorsidedown Well-Known Member
    Dude it doesn’t ride as stiff as people say. Get the HDs and save yourself time and money.
    TegoTaco likes this.
  7. Sep 27, 2018 at 10:39 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I believe it's cheaper to buy the HDs and remove the leaf, instead of buying the MDs and then buying the AAL separate later on.
  8. Sep 27, 2018 at 10:45 AM
    4wdExplorer
    Orange County, CA
    Yeah cant wait. Ordering Kings next month. I have SCS Ray 10 wheels and Icon delta joint UCA's in the garage now.
    Need to get BruteForce fab front and rear bumpers with some custom touches and Vagabond Drifter color matched.
    Is that was you are running without a rear aftermarket bumper?
    I did not know that was an option. I am not familiar with leafs, (coming from the 4runner world). I need to look into this.
  9. Sep 27, 2018 at 10:48 AM
    doorsidedown
    Yes. I have HDs with no constant weight.
    MattCowsmasher likes this.
  10. Sep 27, 2018 at 11:47 AM
    Chase8059
    Chase
    ESVA
    If you search around here it's been talked about. I know I've come across a few threads while searching for general info on the Dakars. I'm in a similar boat as you. I want full packs, but in the next year or so I also want a rear bumper worth swingout.
  11. Sep 27, 2018 at 1:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    As someone who just put the mediums (EL095R) on his truck myself...
    Do yourself a favor, get the HD (EL096R) pack if you are planning on having any consistent weight in the bed. You will be taking the leaf packs apart anyways if you are smart to put some paint on them and to put leaf liners between the leafs and grease everything up proper. While doing so you could pull the 3/4th leaf down to make it a medium pack, or just run the HD pack all together from the get go.
    Superdave1.0 and doorsidedown like this.
  12. Sep 27, 2018 at 1:43 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Just get the heavy duty pack from the get go. I went with the mediums and wish I would've got the heavy duty... I got scared by all the talk of the stiffer ride but its really no big difference (after riding in a truck with the HD's) from the mediums as far as I'm concerned. If you use your bed at all or trailer things you will appreciate the HD.
    lagbc and boston23 like this.
  13. Sep 27, 2018 at 1:53 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I feel the opposite as y’all. I have plated rear bumper and sliders. My medium Dakar’s are stiff as shit. I can jump up and down (195lbs) on my rear bumper and get between 1/4” and 1/2” movement. I towed a 1,500lb enclosed trailer, empty, and it was bone jarring.
  14. Sep 27, 2018 at 2:07 PM
    azzwethinkweiz
    Tucson, AZ
    I must have some weak springs cuz my 160 pound ass gets in the bed and jumps and its like I'm at a low rider meet. lol
  15. Sep 27, 2018 at 2:10 PM
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    I've got the HDs with a topper, which really doesn't weigh that much, and I've been happy with the ride. Not too stiff at all.
  16. Sep 27, 2018 at 2:15 PM
    4wdExplorer
    Orange County, CA
    Awesome, makes sense to go HD then.
    What liners is everyone using? I do not like squeaks and the stock leafs are quiet and do not squeak. I'm willing to unpack the leafs and install the liners for a quiet ride.
  17. Sep 27, 2018 at 2:16 PM
    doorsidedown
    The new ones haven’t squeaked on me yet... I think that was part of the “upgrade” from the CS packs.
  18. Sep 27, 2018 at 2:18 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I don’t have liners on mine, but I greased my bushing inside an out very liberally with moly grease an once on sprayed some fluid film on the leaf packs. I’ve had mine since July an have wheeled with them in really dusty an wet conditions no issues.
  19. Sep 27, 2018 at 2:21 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Also @chmura i went HD’s intially cause they were just a few dollars more but I just have a regular rear HC rear bumper it’s a little stiff but still rides better than stock if this was still on your mind.
    4wdExplorer[OP] likes this.
  20. Sep 27, 2018 at 2:29 PM
    4wdExplorer
    Orange County, CA
    Seems like the best way to go is get the OME HD leafs and if the ride is too still remove a leaf.
    I wont have front/rear steel bumpers until early to mid next year. I hope I will be okay going with HD's. Also I am going with 700 lb coil rate King shocks. Everything too stiff is making me nervous until I get my armor on..
