Rear out of alignment?
Discussion in 'Wheels & Tires' started by USC, Jul 30, 2013.
  1. Jul 30, 2013 at 4:47 PM
    USC
    USC [OP] New Member
    South Carolina
    4x4
    Hello, I just took the tacoma to the dealership for an oil change and had them do an alignment as well. The front alignment was out so they fixed that. They didn't say anything about the rear. I looked up posts other members have on here on there numbers and mine do not match.
    Rear:
    Cross Camber: 0.6
    Total toe: -0.08
    Thrust Angle: 0.12
    Is my camber too high? I know it's ideally supposed to be 0 or it will cause tire wear. And is the total toe supposed to be negative? Any help is greatly appreciated.
  2. Jul 31, 2013 at 12:00 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    You cant do a rear alignment on a solid axle truck. Unless you have frame damage or something is broken then you are ok. Are your tires worn evenly? Also no alignment machine is 100% accurate. So those numbers look ok to me.
