rear park brake cable
Discussion in '1st Gen. Tacomas (1995-2004)' started by onakat, Sep 25, 2016.
  1. Sep 25, 2016 at 8:40 AM
    onakat
    onakat [OP] Well-Known Member
    Canada
    2000 indestructaco!
    Does anyone knows the part # for the rear part of the parking brake cable?
    it's the cable that goes from the pivot point under the cab to the bell cranks on the rear drums
    I have a 2000 SR5 2.7l extended cab automatic 4x4
    My parking brake is not working properly and I think it might be the cable that is just too worn out or stuck. It's not the bell crank pivots because I just changed them, they're brand new. The old ones were broken
    The front part of the cable seems fine, but the rear part definitely has a problem
  2. Sep 25, 2016 at 8:56 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Make sure those cables aren't rubbing on the tops of the leaf springs. Also, check the little levers
    at the backing plates that those cables attach to aren't frozen.
    There are also some adjustments that should be done, one at each of the 2 brake backing plates and
    one at the lever (underneath the driver-side behind the transfer case).
    After the adjustments, then you should check the shoes. Maybe 'de-glaze' them.
    Mush Mouse likes this.
  3. Sep 25, 2016 at 9:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what is your cable not doing??
    What happens when you pull on the e-brake handle??
    Are the rear brakes adjusted??
  4. Sep 25, 2016 at 10:39 AM
    TRDanOR
    TRDanOR Well-Known Member
    Danny
    NB Canada
    02 trd or 4x4 step side
    stock
    check the spot were cables meet on the rear end it has to move free wd 40 it and remove and clean super easy and fix mine.
  5. Sep 25, 2016 at 11:52 AM
    onakat
    Canada
    2000 indestructaco!
    well, it works and doesn't work. Sometimes I pull the handle and I can spin my wheels (the car is currently help up by jacks), which means it is not working. Also the handle is sometimes extremely hard to pull and sometimes there is no tension on it at all when I pull. Same for when I press the button and turn the handle, sometimes it slides on its own into its disengaged position, or sometimes I have to force it down a bit. Also does not fully disengage sometimes, so I have to go shake the cables above the rear diff to disengage it
    about the rear brakes, yes I think they are adjusted. The rear brakes were not working since a very long time (because of bad rear prop. valve) They now work again and they seem perfectly fine. Didn't do any adjustment or anything, so I guess if they are fine, they are already adjusted?
    the cable seems to be stuck inside the black sleeve it's in. I slightly slid the rubber boots off and it's full of black goo (grease?) and I even tried to send a bit of compressed air through it but nothing comes out.
    it's a tension problem. Sometimes I do have tension, sometimes I don't and when it manages to get some tension, it has problems releasing it
  6. Sep 25, 2016 at 11:56 AM
    onakat
    Canada
    2000 indestructaco!
    yeah, My bolt was seized so I changed it, but it didn't solve my problem :/
  7. Sep 25, 2016 at 12:05 PM
    onakat
    Canada
    2000 indestructaco!
    the cables are not rubbing on the leaf springs and my levers and pivots on the back plates of the drums are brand new. Installed and adjusted them yesterday. The pivot near the transfercase didn,t need adjustment, it was fine
    I didn't change my brake shoes, because they are like new, no wear at all. As I said, the rear brakes were not working sine a very very long time. I guess the former owner got his brakes serviced without knowing they didn't work on the rear. The drums have no signs of wear either
  8. Sep 25, 2016 at 12:30 PM
    Cosman
    Cosman Well-Known Member
    San Diego, CA
    2000 Tacoma Single Cab 2.7 4x4 Manual EVERYTHING
    Try putting some Triflow lubricant on the metal cable where it goes into the sleeve. That might help loosen things up.
  9. Sep 25, 2016 at 2:18 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    As the use of the Parking brake keeps the rear shoes adjusted if it does not work or get used
    Rear cable is # 46420-35542
    But double check
  10. Sep 25, 2016 at 5:45 PM
    onakat
    Canada
    2000 indestructaco!
    Yes I did spray some lube inside, but it didn't do anything
    I think the owner before me never used his parking brake, which caused the cable to go bad. Also, the rear brakes were not working since a very very very long time, so it didn't help either.
    thanks for the part number!:):)
  11. Oct 3, 2016 at 11:32 AM
    onakat
    Canada
    2000 indestructaco!
    I changed the cable today and my park brake is now working like a charm.
    The old cable was definitely seized
    thanks again! :)
    TRDanOR likes this.
  12. Oct 3, 2016 at 3:09 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Glad you got it working !!
  13. Nov 1, 2023 at 6:57 AM
    RubyToyTaco
    RubyToyTaco Member
    Ralph
    I have a similar problem but it seems I am missing the large sping that pulls the driver side cable...
    any ideas where I can find a replacement?
    thanks all
    ralph
  14. Nov 1, 2023 at 7:06 AM
    RubyToyTaco
    RubyToyTaco Member
    Ralph
    I have a similar problem but I think I am missing the large spring that holds back the driver side cable...
    thanks all
    ralph
  15. Nov 1, 2023 at 8:55 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Everything is attached to the cable.
    Has your cable been modified in some fashion. Like it broke as was cobbled together rather then replaced?
    The center pivot in the rear needs to be free to move.
  16. Nov 1, 2023 at 9:20 AM
    RubyToyTaco
    RubyToyTaco Member
    Ralph
    Thank you for your help! I am a real Newbie...
    I think the center pivot is frozen/rusted...
    cables seem fine...
    The passenger side works well...just the driver side doesn't move to advance the auto-adjuster
    ralph
    Bivouac likes this.
  17. Nov 1, 2023 at 9:44 AM
    Bivouac
    That sure looks to be the case That has Nylon Bushings on the bolt and a lock nut so that nut and bolt is not tight the lock nut keeps it together.
    That has not moved in quite some time
  18. Nov 1, 2023 at 10:18 AM
    RubyToyTaco
    RubyToyTaco Member
    Ralph
    Great...thanks...
    any idea where I can find a diagram of the setup?
    ralph
  19. Nov 1, 2023 at 10:31 AM
    Bivouac
    Perhaps search for the year Tacoma you have Rear parking brake pivot it should get you close.
    Any of the Factory Service Manuals also would have pictures as well.
    Good Luck.
  20. Nov 1, 2023 at 12:42 PM
    RubyToyTaco
    RubyToyTaco Member
    Ralph
    The bad news is...I broke another bolt!
    The good news is I am getting pretty good at drilling and tapping!
    now to find a replacement!
    thanks again...
    ralph
