Rear Passenger Door Not Unlocking!
Discussion in '1st Gen. Tacomas (1995-2004)' started by enissen33, Feb 19, 2017.
  1. Feb 19, 2017 at 1:46 PM
    enissen33
    enissen33 [OP] New Member
    Emily
    2003 Tacoma PreRunner Double Cab 2WD
    Hi there!
    So here's my problem:
    I have a 2003 Tacoma Pre Runner Double Cab 2WD. I bought it back in September knowing that the rear passenger door didn't open. Well to my surprise, the first time I tried to open the door, it opened! That only lasted for about a week. Since then, it will not unlock. I can't even manually pull the lock. Definitely feels like something is stuck, or even gummed up. When I try to unlock it with my FOB, you can see the lock trying to unlock, but it never goes up all the way.
    How can I fix this? Typically I would take the panel off, but how can I take the panel off if I can't open the door? I'm stumped.
    Thanks!
  2. Feb 19, 2017 at 10:32 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You might need a new door lock actuator. There's a way to test if it's working correctly by applying 12v to a certain set of pins on the harness. Not sure how you can get the door open though.
  3. Feb 19, 2017 at 10:35 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Yup, the door lock actuator is failing. I'm not sure about the 1st gens, but the 2nd gens are costly. I ended up replacing all of my motors instead for $20. Beats paying $200 for each door assembly.
  4. Feb 19, 2017 at 11:13 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Try pressing the unlock and pull at the same time? Just need to get it open once.:D
