rear passenger door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j1999t, Sep 16, 2009.
  1. Sep 16, 2009 at 11:24 AM
    j1999t
    j1999t [OP] Well-Known Member
    Justin
    Northern Colorado
    traded it in
    hey all, my rear passenger door has gone out... the speakers arent working and the window switch is not working on that door or through the main switch...
    any advice?
  2. Sep 16, 2009 at 11:31 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    don't have anyone sit on that side :devil: j/k
    Is this still in warrenty, have you done any recent changes or wiring?
    You mentioned the windows are not working thru the main switch, does it work from the rear passenger door controls?
  3. Sep 16, 2009 at 11:33 AM
    j1999t
    Justin
    Northern Colorado
    traded it in
    this is only under powertrain, but i have access to a shop and alldata if need be... and yes i only changed the speakers out when i got the truck
    and the speaker on that door doesnt work for some reason either, could be a short
  4. Sep 16, 2009 at 11:39 AM
    Jester243
    Dan
    Spokane, WA
    does the window work from the door controls
    I guess it is time to dig into the door?
  5. Sep 16, 2009 at 11:42 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    did someting happen the rubber tube that connects the wires in the door to the truck?
  6. Sep 16, 2009 at 12:10 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    Dunno if there are door specific fuses, but if there are, might have popped one.
  7. Sep 16, 2009 at 12:14 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Driver's door would have control to all windows, try that. If it works it should help narrow down where you need to look. I would think if the main control works but the specific door control doesn't it could be a bad connection somewhere in the door? I don't know how much use it gets or if you have kids who might yank on parts of the truck/door.
  8. Sep 16, 2009 at 3:31 PM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    '11 Tacoma TRD Sport
    3" lift
    had almost exact same problem with my 09. The window switch for the rear passenger door would roll it down, but not back up. and the driver switch would make it go up. so i took it in and they replace something in the passenger door. fo FREE!
  9. Sep 16, 2009 at 5:38 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Sounds like a short or something happened to the conduit into the door... I'd just tear the door apart and start poking around...
