Rear Pinion Seal Nut Torque
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nwcali01, Jul 16, 2019.
  1. Jul 16, 2019 at 4:46 PM
    Nwcali01
    Nwcali01 [OP] Member
    Nico
    1999 Toyota Tacoma 4x4 3.4L V6
    Searched for this for a bit and couldn't find a clear answer...replaced the rear pinion seal in the differential and now can't find the torque specs for the nut. Any info men? Thank you very much!!! 1999 Tacoma SR5 4x4 3.4L
  2. Jul 16, 2019 at 7:40 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Usually you count the threads showing on the pinion nut/ shaft and then mark it so you can reinstall it to the same amount of revolutions and line up your witness mark you made.
    Other than that it gets pretty involved with the preload.
  3. Jul 16, 2019 at 7:42 PM
    Bishop84
    Bishop84 Well-Known Member
    What are you doing. Crush sleave new pinion bearings or just a seal?
  4. Jul 17, 2019 at 6:51 AM
    pulldo
    houston, texas
    He said he replaced the seal, that's the only info I see in his post,,,, fixing to do the same to mine if I ever get off my butt and do it.
  5. Jul 17, 2019 at 5:50 PM
    Bishop84
    I misread somehow. You are right, there is no torque spec. True mechanics training actually teaches to use rotational resistance as a measurement of before and after. But I've always indexed the nut and gone by feel.
