Rear Pinon Seal Question (not asking for P/N or how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Milkman14, Apr 26, 2024.
  1. Apr 26, 2024 at 5:56 AM
    Milkman14
    Milkman14 [OP] Well-Known Member
    2004 Toyota Tacoma 3.4L 4x4 M/T
    Hi Guys,
    In the process of replacing my rear pinon seal. I got the old one out and the new one in but haven't replaced the flange/re-torqued the 30mm yet. I was watching Timmy's video on the matter, and saw that when loosening the 30mm nut he used a pry bar on two of the driveshaft bolts in order to hold it in place. When I removed it, I just set the parking brake and gave it the beans. My question is, did I mess something up in doing it this way (pre-load, backlash, I don't know what else because I don't know very much about this)? If someone can ease my mind, or tell me what I need to check before putting everything back together I would appreciate it. I plan to follow the manual's directions on torquing down the nut.
    https://www.youtube.com/watch?v=iUPMf3y-o9A
    Thank you!
  2. Apr 26, 2024 at 7:22 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Don't worry about it. I'd just reassemble and go. No sense in stressing over it. Send.
    The gold standard likes this.
  3. Apr 26, 2024 at 7:34 AM
    Glamisman
    Glamisman Well-Known Member
    Just like he said ^^^^
    You should be OK. The only caution I can give is dont use an impact to tighten the large nut. There is a crush sleeve that is supposed to be a one time use thing but one replaces it unless they are doing a total overhaul. This sleeve is used to set bearing preload. Tighten your nut to torque and maybe just a smidge more.
    Area51Runner likes this.
  4. Apr 26, 2024 at 8:00 AM
    Milkman14
    Thank you guys, I get nervous over little things. I will re-torque to spec per the manual, maybe give it a hair like you said.
    Area51Runner[QUOTED] likes this.
