Rear proportional valve leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mbcajun, Jan 5, 2017.
  1. Jan 18, 2017 at 4:38 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Yep, exactly what I did,, like I said mine doesn't leak, and I think the reason is because the fluid just passes through instead of pressing on a dead end street like a wheel cylinder. I'm pretty good about flushing all my fluids every couple years and I think that'll stop all that sludge and build up especially getting rid of the moisture in the system. Hope it works out for you, keep us informed.
  2. Jan 18, 2017 at 5:01 PM
    Mbcajun
    Mbcajun [OP] Member
    Perry
    Moss Bluff, La.
    99 white tacoma sr5 4X4 V6 automatic
    Probably got about 50 miles now, good so far. Truck has 266000 miles and probably first time to be flushed.
  3. Jan 18, 2017 at 5:06 PM
    Mbcajun
    Mbcajun [OP] Member
    Perry
    Moss Bluff, La.
    I did bye the boot and bushing kit . My boots were torn on both ends allowing moisture and dirt to get to end of spool. I'm sure that will help also.
