REAR QA1 COILOVERS / 4-LINK / 95.5-04 TACOMA 5 LUG
Discussion in 'Street Trucks' started by Beefed Taco, Jun 1, 2012.
  1. Jun 1, 2012 at 1:42 PM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    The STREETACOS 4-link kit
    In this first post I'm just going to provide shock part #'s so anyone interested in doing this will know exactly what I'm using. Pictured below is the kit that's needed.
    (2) SHOCKS - PART # DS502 / ADJUSTER RINGS / BUSHING SLEEVES
    The only items in this kit below that won't be used are the 1/2" sleeves that press into the shock bushings. Each box contains a shock, adjuster rings, and a bag with (4) gold bushings. (2) that accept a 5/8" bolt, and (2) that accept a 1/2" bolt. You can toss the smaller 1/2" stuff because my kit uses 5/8" yellow coated fine thread grade 8 hardware.
    I'll keep the pics coming as this build progresses. I'm currently building two kits.
  2. Jun 1, 2012 at 3:28 PM
    pinktaco808
    pinktaco808 Hot Steppa
    pricetag?
  3. Jun 1, 2012 at 7:31 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :jerkoff::drool:so is the bolt on 4 link officially done now! That thing is brilliant! Cant wait to see it on his truck and some auto x cornering!
  4. Jun 2, 2012 at 12:52 AM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    if....no...when i get another 5 lug, im calling you up!
  5. Jun 5, 2012 at 3:28 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    so how bout that 05+ stuff? lol thats beast dude, great work.
  6. Jul 11, 2012 at 7:52 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    First time I have seen the complete kit Brian.
    I looks great! Props buddy!
    Gimme a call sometime homo....:cool:
