Rear Quarter Window Latch Fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rusty White Taco, May 25, 2011.
  1. May 25, 2011 at 7:56 AM
    Rusty White Taco
    Rusty White Taco [OP] Active Member
    Central Coast, CA
    04 4x4 Xtra Cab TRD Offroad SR5
    Debadged, Front 5100s at 2.5, 1" rear shackle lift, 5125s in the rear, trimmed exhaust pipe
    As many 1st gen xtra cab owners have, I have had issues with the rear quarter window latch. The plastic arm is not terribly strong and tends to break, and one of mine was broken. I couldn't bring myself to spend $30 to buy the factory replacement because there's nothing that tells me the new one won't break too.
    So, I looked for a more permanent solution, and came across someone who makes a billet replacement. Unfortunately, the guy did not return my calls (despite the fact that he's local to me and I offered to bring cash whenever it was convenient for him). He has a website with a store, but if he won't return calls, there's no way I'm going to provide him with my credit card. That aside, there were reports that his part didn't always work well, so that was further motivation to stay away from him. Here's a thread about the billet replacement and the guy: http://www.tacomaworld.com/forum/1st-gen-tacomas/103220-access-cab-1-4-glass.html
    Anyway, with the above in mind, I set out to make a replacement part out of steel. Here's what I did:
    Took a piece of scrap steel I had in the garage (1 1/4" x 1/8") and cut it to length. Unfortunately, I only had 1/8" steel and the original plastic arm is 3/8", but I went for it anyway (hoping that 1/8" would work):
    Took the broken arm and traced around it to set the general shape:
    Cut, grinded, and filed the steel until it matched the original and then drilled two 11/64" holes for the pins (I didn't take pictures of the refining of the shape because I wasn't terribly confident it would actually work):
    Painted it:
    Test fit it:
    Installed it:
    It worked the first time. It was a perfect fit.
    I just thought I'd share a solution that can be accomplished with about $0.25 in parts (steel) and some elbow grease...
  2. May 25, 2011 at 8:20 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    nicee i might have to check that out one of mine broke too!
  3. May 25, 2011 at 8:39 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Nice fix. I wish I would have thought about doing this. I bought the billet ones and they work pretty good. I had to bend the piece attached to the cab a little so the window would close tight, but I haven't had any problems since.
  4. May 25, 2011 at 9:13 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Yeah I bought the aluminum ones that you refered to and I also e mailed the guy to tell him they were shit and never got a return e mail, I don't use the quarter glass windows but if I were to replace a broken latch I would go back to the OEM.
  5. May 25, 2011 at 2:32 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Nice write up, mine have been busted for years. I've never bothered to fix em since I never use those windows but if I ever do get around to it this is how ill do it for sure.
  6. May 25, 2011 at 7:38 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    very nice! i broke mine whenever i leaned my truck into a tree...I'll definitely have to do this.
    You could always make 3 of em if you want it to fill out the space.
  7. May 26, 2011 at 11:22 AM
    Rusty White Taco
    Central Coast, CA
    Thanks! Yeah, I had originally planned to make 3 of them, then tack weld them together, but based on the fact that it works fine with just one and the fact that it was not easy to refine the shape of one, let alone 3, I am just going to leave well enough alone. I may fill in the extra space with a 1/4" spacer of some sort if/when I'm bored and feel the need to mess with the rig...
  8. May 28, 2011 at 12:49 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
  9. May 28, 2011 at 9:13 AM
    Rusty White Taco
    Central Coast, CA
  10. Jun 1, 2011 at 10:43 AM
    Sign Guy
    Sign Guy Well-Known Member
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Nice Rims, Big Tires, Carryboy Shell, Added Rosta Cruise Control & Ultraguage, 5100 Bilsteins All around
    Thanks for that tip. I'm gonna make one for mine now. I was pretty ticked when I opened up the window and couldn't close it because of that part. I think I'm also missing a pin that I can probably get at a hardware store too.
  11. Jul 29, 2018 at 2:38 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Hey.. which area did you bend to get the latch to stay shut? I bought the bikebi replacements too. One constantly opens and drives me nuts... You mean the only metal attached to the can/truck ?and which way did you bend it.
    Thanks
  12. Jul 31, 2018 at 9:36 PM
    Tacomasapien
    Tacomasapien New Member
    Cory, this is apparently an old thread and I don't know if you'll get reply from the previous posters. I am having the same problem as you. I replaced my billet swivels but the latches still work their way open. I also read the 'bending' idea and will try it out and let you know. If you've already tried it, please let me know which way you bent it asap (on this thread) before I try it. Thanks!
  13. Aug 2, 2018 at 8:07 PM
    Tacomasapien
    Okay, Cory or anyone interested. If your latch won't stay closed or constantly works it's way open, the fix is easy as hell: With the latch opened, from the inside of your Taco, grab the black bracket with you finger and carefully bend in inward (see photo). Just do a little at a time, so you don't go too far. Good luck!
    Taco_Mayhem and frizzman like this.
  14. Jan 9, 2019 at 12:10 PM
    Taco_Mayhem
    Taco_Mayhem New Member
    The King AdRock
    2004 4x4 TRD SR5
    HIDs, Halos, and turn signal / DRL mod Icon Vehicle Dynamics: front coil-overs, UCAs, and rear struts Dakar / Old Man Emu Leaf packs + AAL Skid Row skid plate Demello rock sliders welded frame reinforcement over rear c-channel CBI Offroad rear bumper Toyota FJ TRD wheels (16 x 7.5) camper shell, Rhino Rack, bedliner lift stuff: extended travel / offroad CV boots, brake line extension, exhaust reloactor big tire stuff: 1/8" front wheel spacer, 1.25" rear wheel spacer AirRaid air intake white wire mod for rear diff locker loud horns AZ window tint deck and speakers
    Thank you! ^
  15. Jan 9, 2019 at 2:44 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Tacomaworld! Always there when you are in need!
  16. Jan 9, 2019 at 3:52 PM
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
  17. Jan 9, 2019 at 4:01 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  18. Jan 9, 2019 at 4:02 PM
    eimkeith
    J Keith
  19. Jan 10, 2019 at 11:53 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
  20. Jan 11, 2019 at 12:48 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I kinda like that mine broke because I can fit the mag mount for my ham radio antenna through the open window now.
    I'll probably replicate this when I upgrade my antenna.
