Rear recovery point without tow hitch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mastiff37, Feb 6, 2021.
  1. Feb 8, 2021 at 7:17 AM
    Mastiff37
    Mastiff37 [OP] Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    I don't understand. Do you mean the bumper is hanging down lower than it needs to?
  2. Feb 8, 2021 at 10:47 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    The bumper attaches to the hitch. If you remove the hitch you need the brackets. The hitch is heavy so once it's removed your suspension will not sag as much, causing the rear end to sit a bit higher.
  3. Feb 8, 2021 at 10:57 AM
    Mastiff37
    Tucson, AZ
    My hitch is aftermarket, drawtite or something like that. But it's just a 2.5" piece of square tubing with brackets. I can't believe it weighs more than 25 lbs.
  4. Feb 8, 2021 at 1:45 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Before you remove it you probably want to confirm if the bumper is bolted to the hitch so you know if you need the brackets. I'm not sure how aftermarket receivers attach.
