Rear reservoir mounting.
Discussion in 'Suspension' started by brian, Jul 30, 2011.
  1. Jul 30, 2011 at 6:13 PM
    brian
    brian [OP] Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I jumped on the deal from DSM a few days ago. I got my rears installed, and for now I piggybacked the reservoirs, but the lines are a little long and after doubleing back, they come a little close to the tire. Probably nothing to worry about but I think I want to mount them somewhere else.
    They came with the weld-on mounts from DSM, but what I'm thinking about doing is drilling the tabs on the mounts and attaching them to the bed inside the fender well. I would use machine bolts to the right length and keep the heads inside the bed, adding a rubber washer to prevent water intrusion.
    Has anyone done this? While I can get someone with a welder, it just seems easier to do things this way. Only downside is that is they are a little more in view, becoming flashy to the public.
    Ideas? Mainly I'm just looking for opinions, I'm pretty sure it will work with no problems.
  2. Jul 30, 2011 at 6:18 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    drilled holes in the frame for mine. no issues with theft, but i live in a pretty safe area as well.
  3. Jul 30, 2011 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. Jul 30, 2011 at 6:23 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    will these work with a truck with a 6 inch lift? they look cool..
  5. Jul 30, 2011 at 6:33 PM
    brian
    Elizabeth City, NC
    You guys don't care that its rubbing on the bump stop?
  6. Jul 30, 2011 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not rubbing. I have about 1/4" of clearance, and there are no signs of wear on the hose.
  7. Jul 30, 2011 at 7:00 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    i have the same Icons, and they don't rub either.
  8. Jul 30, 2011 at 8:08 PM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    You'll be fine on the bump stop mounts as long as you place the mounts with the shocks on. Another thing to watch is the hose rubbing the side of the shock mount. If you angle the fittings out a little bit to clear the shock mounts you'll have a perfect gap when it comes to the bumpstops
  9. Jul 30, 2011 at 8:16 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you won't have any clearance issues
  10. Jul 30, 2011 at 8:23 PM
    05offroad
    Michael
    I've lost track
    That's exactly it. As long as you set the shock and an angle and tighten it down pretty far so it wont rotate, you'll be good to go
  11. Jul 30, 2011 at 8:29 PM
    brian
    Elizabeth City, NC
    Wasn't worried about clearance mounting em that way, I knew they'd clear...haha.
    Thanks guys, I guess Ill drill into the frame, even though I don't want to.
  12. Jul 30, 2011 at 8:31 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'm confused what clearance you're worried about then.
  13. Jul 30, 2011 at 8:32 PM
    05offroad
    Michael
    I've lost track
    Why don't you weld on tabs or have some welded on? Then if you take them off for whatever reason you won't have holes
  14. Jul 30, 2011 at 8:47 PM
    brian
    Elizabeth City, NC
    I have them.
    The whole original point of this post is to see if anyone had mounted them to the bed. Instead, I got tons of pictures of what I already knew. Obviously no one has done it... it was just a random idea that would make life pretty easy.
    Either way, I'm not doing anything until next weekend probably, which is mod day, so a welder, or a drill will be present.
    The clearance issue was due to the fact that I have them currently piggybacked, its only temporary.
  15. Jul 30, 2011 at 8:50 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    oh, i see. i thought you were talking about clearance with them mounted to the frame or bed, didn't realize you were talking about while they were piggybacked. my bad.
  16. Jul 30, 2011 at 10:26 PM
    05offroad
    Michael
    I've lost track
    Oh I see. You could move your bump stop to the axle, so it would hit the frame. cut the factory strike plate off and move the shock mount to the spot where it was. Only ting to worry about then is the length of the shock housing
  17. Sep 14, 2019 at 10:34 AM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Hey guys this is my first time putting on my fox 2.5 resi with adjusters. Shocks are on just need the resi part I don't know how to mount it came with the brackets.
