Rear Right Window Wont Go Up Or Down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loud05Taco, Mar 5, 2018.
  1. Mar 5, 2018 at 3:50 PM
    Loud05Taco
    Loud05Taco [OP] Member
    Zach
    2005 Toyota Tacoma TRD Off-Road Prerunner
    Bilstein 5100's front and back (leveled) Enkei WT4's Color Matched handles and mirrors w/ base Ever changing SPL audio build
    2005 dbl cab
    All windows work perfectly, except for the rear right window
    The front master switch doesn't work for the window, neither does the rear right door switch.
    Has anyone else had this issue?! If so let me know if you have a solution
    Thanks, Zach
  2. Mar 5, 2018 at 6:53 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Assuming the child lock is off, sounds like you have a bad regulator, or associated wiring... All other windows work? Easy to pop off the door panel and test it with +12v
  3. Mar 5, 2018 at 7:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Can you hear a motor turning in the door?
  4. Mar 5, 2018 at 11:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Defective regulator and or motor.
