Rear Roar
Discussion in '1st Gen. Tacomas (1995-2004)' started by s.morris, Dec 7, 2009.
  1. Dec 7, 2009 at 6:29 PM
    s.morris
    s.morris [OP] Member
    Howdy everyone,
    I just picked up a 2000 2wd Tacoma with 150000 miles on it. It drives good, the only thing is at lower speeds and periodically at highway speed I hear a roaring sound. I am in a single cab so the sound is amplified and I was curious what you guys think. This sound like a bad wheel bearing?
  2. Dec 7, 2009 at 6:55 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    roaring?
    only thing i can think of that would roar would be a bad muffler or catalytic converter...
    are you sure that the sound is a roar? not a metal on metal grinding?
  3. Dec 7, 2009 at 7:10 PM
    s.morris
    Well it definately doesn't sound like a grinding noise. It happens mostly at a lower speed, either acellerating to or decellerating down to a lower speed. It will periodically roar a little while I drive at a higher speed. It is a small single cab though, so maybe I am just not used to having the sound reverberate so strongly while I drive, but it just seems like there shouldn't be that sound. It almost sounds like momentary riding with someone who has a loud exhaust on there car.
  4. Dec 7, 2009 at 7:28 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    if it seems like an air flow roar everytime ur RPMs go up then its an exhaust leak or aftermarket muffler
  5. Dec 7, 2009 at 7:39 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    does the sound change when you turn the steering wheel side to side at about 45 or so?
  6. Dec 7, 2009 at 8:20 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Only thing came to mind is your Fan. Do you have an idea where its coming from?
  7. Dec 7, 2009 at 9:47 PM
    s.morris
    First and foremost, thanks for the responses so far guys.
    To answer the question though, no it does not make noise when I turn the wheel or at 45 degrees. I actually drove a truck with bad CV joints last week and this sound definately does not sound like that awfull grinding noise. This sounds more like an exhaust sound so I am probably going to go and take it to get it checked out tomorrow. Do you guys think it be better for me to take it to toyota or just to a local mechanic? Also, I have the stock tires on it as of right now and the ride isn't the smoothest in the world. Is there any way I could smoothen the ride up a little on it? Different Tires maybe?
  8. Dec 7, 2009 at 9:48 PM
    s.morris
    O yea, and it sounds like it is coming from the rear.
  9. Dec 7, 2009 at 9:53 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    take it to a muffler shop... have them listen to it first...
