Rear running lights not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boatin, Jan 13, 2019.
  1. Jan 13, 2019 at 8:40 AM
    Boatin
    Boatin [OP] Member
    White tacoma
    I have a 2017 off road double cab short bed the rear running lights are not working along with the license plate lights. Everything else works break turn reversed all the fuses under the hood checked out kind of stumped any thoughts
  2. Jan 13, 2019 at 9:52 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Stock?
    Something makes me suspect not...
    All your headlight parking and marker lights work?
    Chew likes this.
  3. Jan 13, 2019 at 9:56 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Did you check interior fuse panel?
  4. Jan 13, 2019 at 12:25 PM
    Boatin
    Boatin [OP] Member
    White tacoma
    All stock and where is the interior fuse panel
  5. Jan 13, 2019 at 12:35 PM
    Boatin
    Boatin [OP] Member
    White tacoma
    Split bolt yes everything is working except the rear running lights and the license plate lights that’s it
  6. Jan 13, 2019 at 12:48 PM
    Boatin
    Boatin [OP] Member
    White tacoma
    Found the issue bad fuse in the cab problem is it blows every time you turn the lights on so I have a short somewhere working on that now thanks everyone
    shakerhood likes this.
  7. Jan 13, 2019 at 12:53 PM
    splitbolt
    NW Arkansas
    That should eliminate the 7.5A TAIL fuse and TAIL relay.
    I'd look at connector EB1.
  8. Jan 13, 2019 at 1:40 PM
    Boatin
    Boatin [OP] Member
    White tacoma
    Actually the 7.5 amp tail fuse is the one that keeps blowing the truck still under warranty so I’ll send it to the shop thanks again
  9. Jan 13, 2019 at 2:32 PM
    splitbolt
    NW Arkansas
    That has me scratching my head, since that same fuse does the parking and marker lights in your headlights; yet, they still work.
  10. Jan 13, 2019 at 2:59 PM
    Boatin
    Boatin [OP] Member
    White tacoma
    Yes me also not sure what the deal is everything on the truck works except the tail running lights and the license plate lights bulbs rang out fine not sure what the deal is
  11. Jan 13, 2019 at 3:00 PM
    Boatin
    Boatin [OP] Member
    White tacoma
    I have not done any modifications to the truck since I noticed this so I’m not exactly sure what’s going on seems like there’s a short somewhere
  12. May 4, 2020 at 11:40 AM
    marcosis12
    marcosis12 New Member
    @Boatin , did you find out a fix? I am having the same issue and scratching my head on what to do.
  13. May 4, 2020 at 11:48 AM
    Boatin
    Boatin [OP] Member
    White tacoma
    Yes there was a bad light bulb in one of the tail lights
  14. May 4, 2020 at 11:50 AM
    Boatin
    Boatin [OP] Member
    White tacoma
    There was a short in the bulb I never saw one like that the bulbs tail lights everything was complete factory oem
