Rear Sag help on 1st Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by ixsanctifiedxi, Jun 3, 2011.
  1. Jun 3, 2011 at 9:26 AM
    ixsanctifiedxi
    ixsanctifiedxi [OP] II corinthians 5:21
    Aaron
    Lynchburg, VA
    02 3.4L Double Cab 4x4
    Deck Plate Mod, OME 881's on 5100's set to 0", Dakar leafs in the rear with 5100's...
    Hey guys... I really hope I'm not beating a dead horse with this question but I've literally searched and searched and couldn't find a straight answer to what i was looking for...
    So I'm ordering my Billys all around from DSM, and when I was measuring the ground to fender I noticed that my driver rear is sagging and its sitting at 35".... The passenger rear is at 36.5".... my whole point in getting the Billys is to level out the truck, but with the back sagging how will that work? Since I'm going billys all around, will that correct the sag or am I going to have to get an AAL? or to replace the faulty leaf(s) on the drivers side?
    Thanks guys for all the help....
  2. Jun 3, 2011 at 9:30 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    that is known as the taco lean, all tacomas have it i believe. i think some people use like 1/4 spacers to fix this
  3. Jun 3, 2011 at 9:30 AM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    Go to my thread rear leaf fix $$$$$. That is what I did and it is working great.
  4. Jun 3, 2011 at 9:32 AM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    haha I think I read your thread on fixing it... I don't have anyone with an f-350 or equivalent... don't think I didn't think really long and hard about it though haha....
  5. Jun 3, 2011 at 9:32 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    If your leaf packs are that bad the AAL will only put a bandage on it and it will start sagging again. Mine were pretty bad and I didn't get much lift with the AAL so I removed it and bought new leafs. The 5100's will not lift your truck in the back so you will need to fix the leafs before or you will be ass low.
  6. Jun 3, 2011 at 9:34 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Shocks in the rear of the truck do not give any lift. Are your leaf springs flat or have a negative arch? If they do they probably need replaced. That difference in heights passenger side to driver side is the taco lean lol.
  7. Jun 3, 2011 at 9:34 AM
    kmok
    Kyle
    Columbus, Ohio
    Beat me to it lol
  8. Jun 3, 2011 at 10:05 AM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    so basically replace the rear leaf packs? any suggestions on which to get? I plan on trailing a few times a year (once a month or so) but this is mainly a daily driver....
  9. Jun 3, 2011 at 12:00 PM
    TacoSID138
    TacoSID138 Well-Known Member
    SoCal
    04 PreRunner TRD
    Faded out tinted tails and 3rd brake light,deck-plate mod, dumped Flow Master 40, King EXTD coil overs, 1.5 AP shackles, AP EXPD leafs. 285 Hankook DynaPro ATM tires
    are you looking to lift it or stay at stock height? wheelers has a few different leaf packs, for stock height and 1.5" of lift i believe. if myou want to go higher there is all pro they have a 3" leaf pack
  10. Jun 10, 2011 at 10:22 AM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    So... I was retarded and where I measured my truck I was on a slight incline... I re-messured it on level ground and the difference was less that 1/2" between driver and passenger sides... I ordered my billies today and am looking at getting a 1.5" -2" AAL soon... I'm on my way to my first mod!
  11. Jun 10, 2011 at 3:49 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    You're about to embark on a beautiful journey to a big pit. It's filled with money, and you can't resist throwing some in. You'll continue throwing money until you have no more...then you'll turn around and your truck will be super awesome, and you'll smile.
  12. Jun 12, 2011 at 8:52 PM
    donniejacks
    donniejacks Member
    Donnie
    Chesapeake,OH
    1995 Toyota Tacoma 4x4
    None
    what is the best leaf springs to get mine is broken on the passenger side and sagging altogether on the driver side.
  13. Jun 12, 2011 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  14. Jun 14, 2011 at 10:19 AM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    Did you have to replace the UCA's when you did that??
  15. Jun 14, 2011 at 5:21 PM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    I'm really considering it, because I wasn't sure I wanted to run stock coils on new shocks... I figured if I'm gonna do the shocks why not the springs too... and it's not that much more expensive... I'll have to wait a pay check or two (moving to a new place 1st of July) to get the coils and AAL from Toyotec, but it will be worth it I think... if I'm doing it might as well do it right...
  16. Jun 14, 2011 at 7:34 PM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    Girlfriends dad is the service manager at the local Honda place. He said he could hook me up on the install. Thanks for the help bud.
  17. Jun 15, 2011 at 1:20 PM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    I learned a lot here,
    sub'd for future leaf purchase ;)
  18. Jun 16, 2011 at 11:24 AM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    haha thanks for the heads up ... it maybe a few weeks from now but I'll post some pics once I get it all in and installed!!
  19. Jun 17, 2011 at 9:31 AM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    So I'm thinking since I'm doing it right, instead of doing an AAL in the rear, why not get the OME Dakars? how do they match up with the 5100s all around, and the Eibachs?
  20. Jun 17, 2011 at 9:34 AM
    kmok
    Kyle
    Columbus, Ohio
    The OME Dakar pack will be a much better than just getting an AAL. That's basically my suspension setup and I like it.
