Rear Seat Organizer (under & behind)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nola_jim, Nov 27, 2018.
  1. Feb 15, 2021 at 11:40 AM
    #301
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    I’m a happy Taco :taco:
    Demirod and nola_jim[OP] like this.
  2. Feb 15, 2021 at 7:59 PM
    #302
    whatisraytaco
    whatisraytaco Well-Known Member
  3. Feb 23, 2021 at 3:53 PM
    #303
    Overland&UpMoutains
    Parker
    Deleware
    77A85FB7-E052-4A0E-87B9-16805DC61BF2.jpg Rear seat delete but still able to use the divider!
  4. Feb 23, 2021 at 8:24 PM
    #304
    1Crusader
    1Crusader Well-Known Member
    2020 SR5
    Definitely interested in a set.
  5. Feb 24, 2021 at 8:47 AM
    #305
    brkncly
    brkncly Well-Known Member
    2017 White Tacoma TRD Offroad
    I'm also interested in a set!
  6. Feb 24, 2021 at 9:36 AM
    #306
    suprdave04
    suprdave04 New Member
    Henderson NV
    2021 Tacoma TRD Off Road
    Interested as well
  7. Feb 24, 2021 at 10:31 AM
    #307
    jeejay
    jeejay Well-Known Member
    Jino
    SoCal
    '20 Tacoma Ltd MGM 4WD
    1st 2020 Nightshade Conversion|RetraxPro XR|DesertDoesIt Front Seat Jackers|Meso Customs V2 Ultimate Dome Lights|Meso Customs V2 Maplight Dual Mode|OEM 2nd Gen running boards|OEM bed lights|OEM tailgate lock|OEM bed mat|Meso Total Tail Stage 1|AVS Side Window Deflectors|Liftd Gas Cap Holder|Meso Headlight Trim Plates
    Interested as well!
  8. Feb 24, 2021 at 12:33 PM
    #308
    Demirod
    Demirod Member
    CA
    2018 Tacoma Off Road
    I definitely need a set !
  9. Feb 24, 2021 at 4:46 PM
    #309
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    I have an Access Cab and I keep a fire extinguisher and jumper cables in the bins under the back seats (to the extent not occupied by the bottle jack and spare tire tools). Subdividing that space would prevent carrying (relatively) large objects like that. Counterproductive, IMO.
    The same thinking goes for subdividing the console compartment. Doing so would make it less useful. (A console tray, on the other hand, is very useful.)
  10. Mar 24, 2021 at 2:49 PM
    #310
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    I've got a set that I cannot use. @nola_jim and I have written each other, and he knows I'm selling it in this thread. I bought it from him on Ebay on Feb 19, 2021 for $27 plus $15.20 shipping. Same cost ($42.20) to ship it to you. Drop me a line.
    SOLD
    Demirod likes this.
  11. Mar 24, 2021 at 5:09 PM
    #311
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Maybe it’s just me but I never got the idea behind these so-called “organizers”. I mean, all that stuff would still fit there without the dividers breaking up the room into smaller spaces, but a larger item that otherwise would now won’t.
    Same as drawer systems in a bed. They just occupy or take up more space that an otherwise larger item would fit into without them. Seems like a psychological gain but not an actual gain.
    Anybody else with me, or am I just fucked up in my way of thinking?
  12. Mar 24, 2021 at 6:33 PM
    #312
    JFanaselle
    JFanaselle Well-Known Member
    Joe
    Murrieta, CA
    2020 TRD Off-Road DCSB 4x4
    It is an "organizer," which is about convenience, not increasing space. You are correct that the items will still take up the same amount of room (or maybe even less room) without the organizer. But it's the same concept as a file cabinet - you can either have a giant stack of paper (which would be smaller than a file cabinet), or you can have a cabinet/box that it all organizes neatly into, so that you can quickly access what you need. For me, the organizer allows me to quickly grab a pair of gloves or a can of WD-40 without having to dig through a bunch of tow straps or pull a bunch of other stuff out first.
    Same concept with bed storage systems. Sure, you could pile your bed from floor to top with tools and misc. items, but as soon as you need the tool at the very bottom of the very back, it's going to be hell to get it. If you have a long drawer with dividers in it, you can easily and quickly access every item that you have in the bed. I am in agreement with you, however, that some of these drawer systems are way too big. I am huge on using virtually all available space, and I can't stand seeing some of these setups that literally waste tremendous amounts of cubic volume. I understand that you need to sacrifice a little bit of space for the sake of organization (back to my file cabinet reference), but I'm not going to consume half of my bed for what can fit into a simple toolbox.
  13. Mar 24, 2021 at 9:20 PM
    #313
    Dryfly24
    George
    NM
    My feelings exactly.
    JFanaselle[QUOTED] likes this.
  14. Apr 8, 2021 at 9:09 PM
    #314
    Captkirk77
    Captkirk77 Member
    Rob
    2018 Barcelona Red TRD Off Road 4x4
    I'm interested in the under seat organizer and rear passenger seat organizer. Are anymore going to be made because I'm looking to buy!
  15. Apr 9, 2021 at 6:52 AM
    #315
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    I am also interested.
  16. May 11, 2021 at 7:04 PM
    #316
    MikeTyler10x
    MikeTyler10x Member
    Tyler
    Is there any chance of more of these?
  17. May 12, 2021 at 7:07 AM
    #317
    nola_jim
    nola_jim [OP] Well-Known Member
    Jim
    New Orleans
    2017 Toyota Tacoma Off-Road, 6 Speed MT
    Cosmetic
  18. Sep 8, 2021 at 7:44 PM
    #318
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    Also wanting some
  19. Oct 2, 2021 at 11:24 AM
    #319
    nola_jim
    Jim
    New Orleans
    Cosmetic
    Link was down for a bit for Hurricane Ida, but back up and running now!
  20. Nov 30, 2021 at 4:22 PM
    #320
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    @nola_jim gunna have some available soon?
