Rear Seat Replacement Idea DBL Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TjBjornsen, Aug 20, 2016.
  1. Aug 20, 2016 at 8:26 AM
    TjBjornsen
    TjBjornsen [OP] Active Member
    Greetings All,
    Just got a 2012 DCLB, and am already thinking of ways to "make it my own..."
    I've looked around a bit and have not seen anything as described below.
    For the Access Cab models you can specify a "Contractor Option" or something like that, that leaves out all of the rear seat assemblies, and replaces them with plastic panels and bins.
    I would have thought that someone on the aftermarket side of the fence would have come up with some a product that would allow you to do this with either side of the back seat in a Double Cab.
    You Can unbolt both the upper and lower seat units, and take out the plastic bin that is behind either seat assembly, leaving you with a substantial amount of space for tools, bags, whatever, to carry around in the cab, behind the front seat.
    Is no one making a drop in/bolt in plastic bin system of some sort that will replace the seats if removed from a Double Cab?
    I'm guessing that a weekend with a jigsaw, a pile of zip ties, my plastic welder and some "found 'em, fair and square" plastic milk cartons I could fashion something up,
    But this has to have been thought of before, No?
    Thanks in advance for a great site,
    Already learning and utilizing it a bunch.
    TjB
  2. Aug 20, 2016 at 8:30 AM
    medic2230
    Murph
    Bama! Roll Tide
    I've seen a few guys on here make something like a wooden deck to go in the back. You could do that and cover it with a fabric like they cover speaker boxed with. I haven't seen a commercial product though. There may be one I just haven't seen it yet.
  3. Aug 20, 2016 at 7:36 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Whatever you fabricate and install, consider what can happen in an accident. Anything loose in bins, shelves, etc becomes a high speed and potentially lethal projectile. That goes for the bins or shelves themselves too. Do it right.
    Skyway, jpmorrisvb and landphil like this.
  4. Aug 21, 2016 at 2:28 AM
    TjBjornsen
    That is a very good point, and one that I always try to take into account.
