Rear Shaft Joint leaking grease by Transfer Case
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LTDSilver16, Dec 31, 2023.
  1. Dec 31, 2023 at 5:31 PM
    LTDSilver16
    LTDSilver16 [OP] Member
    I was looking underneath my 2016 Limited 4x4 Taco for something else when I happened to notice this leak coming from what appears to be where the rear shaft connects to the Transfer Case. Should I be concerned yet? Any fixes?
  2. Dec 31, 2023 at 5:45 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Were your Zerks recently greased? Do you notice any driveline clunks or noise? Also how many miles on your truck?
    Chew likes this.
  3. Dec 31, 2023 at 5:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The U-joints are supposed to be greased yearly. You usually can't clean up the old expelled grease 100%. Whatever old grease remaining outside the joint will splash when the driveshaft spins, like it's shown here.
    Chew and TnShooter like this.
  4. Dec 31, 2023 at 5:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That’s not a leak.
    It’s from greasing the u-joints.
    I WANT to see that. That means the joints were greased.
    A good tech can wipe off the excess grease to control the “sling”.
    But I’m not a tech, and I don’t care.
    Chew likes this.
