Rear shock advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cjtacoma69, Feb 4, 2023.
  1. Feb 4, 2023 at 9:58 AM
    Cjtacoma69
    Cjtacoma69 [OP] Member
    2006 Black Tacoma Sport
    6 inch lift
    Any reccomendations for rear shocks of decent quality that won't break the bank? I have a 2006 4WD with a 5 inch lift and big tires. Anything will help! Toyota says it'll cost me 530 dollars to fix hahaha
  2. Feb 4, 2023 at 10:23 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Welcome to TW
    Try searching in the suspension section
    Cjtacoma69[OP] and ZColorado like this.
  3. Feb 4, 2023 at 10:29 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    The suspension section would be ideal.
    Bilstein 5100 at a minimum. BP51, King, Fox on the high end (with much higher maintenance)
    Cjtacoma69[OP] likes this.
  4. Feb 4, 2023 at 10:33 AM
    Cjtacoma69
    6 inch lift
    Still learning the site. Thanks guys!
    69 Jim and ZColorado like this.
  5. Feb 4, 2023 at 10:50 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    5in lift?
  6. Feb 4, 2023 at 10:52 AM
    Cjtacoma69
    6 inch lift
    Either a 5 or 6 I bought it lifted a few years ago and don't exactly remember
  7. Feb 4, 2023 at 12:50 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Check out Torch Off Road. I believe they have extended rear shocks for 5" lifts
  8. Feb 4, 2023 at 3:12 PM
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    Op ,Is this lift from a change of leaf springs , or blocks ? Either way assuming you are sticking with that lift , you might want to figure out your measurements : full stuff , full droop etc. before you lay down some cash….you don’t want your shocks being your “bump stops”
  9. Feb 4, 2023 at 3:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Most 5-6" lift kits are only 4" in the rear, so you need to measure out what it has.
