Rear shock almost fell off! Need help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tj2002, Mar 31, 2025.
  1. Mar 31, 2025 at 1:46 PM
    Tj2002
    Tj2002 [OP] Member
    Tacoma SR5 2002
    Stock
    The upper end of my rear left shock came loose. Shock swung down and dragged the highway. Temporary tied up loosely with bailing wire to frame. It appears that the bolt or nut backed out as well as the assumed blushing and the shock vibrated out of position. No parts were found in the immediate vicinity. Need help figuring out what parts are I need. Is it a bolt or a nut?And what size? Can these be purchased easily? And what about the bushings. Gonna wait to crawl under in case anyone has questions I need to look for...
  2. Mar 31, 2025 at 1:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^It's a spigot welded on the frame. The center of the spigot has a threaded hole. The shock bushing goes over the spigot. Then a bolt with large washer is threaded on the end to trap the bushing in place.
    A few other ways it could have failed:
    The bolt broke due to rust
    The spigot broke off from the frame due to rust
    The shock bushing hoop broke off from the shock shaft due to rust
  3. Mar 31, 2025 at 1:56 PM
    Tj2002
    Tj2002 [OP] Member
    Tacoma SR5 2002
    Stock
    Yes I agree with that description. I just got under and confirmed it.And have pictures. I'm trying to determine the size of the bolt and length As well as where to find the bushings. Are the bottom ones the same size?
  4. Mar 31, 2025 at 2:19 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are the shocks original equipment? If so consider replacing both shocks, bushings, bolts etc.
    Moonrman likes this.
  5. Mar 31, 2025 at 2:22 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Best route it to just go buy two new shocks. The upper portion hardware will come with the shocks. All you will need to reuse is the lower bolt. No need to go crazy, whatever oem replacement your local auto store has will be fine if you are stock. Prior to this, with you having a 1st gen. Prior to doing any of this locate the mounting points and ensure your frame is good and they are where they should be.
  6. Mar 31, 2025 at 3:32 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Those bolts usually don't spontaneously separate. Somethings afoot
    TRD-ED and Black97v6MT like this.
  7. Mar 31, 2025 at 3:49 PM
    Tj2002
    Tj2002 [OP] Member
    Tacoma SR5 2002
    Stock
    I replaced the shocks a year ago. I have no doubt I am to blame for failing to torque them properly. I have already found replacement bolt and washer.. but finding the correct replacement bushings without having to buy new shocks all over again is not going well so far.
    3JOH22A likes this.
  8. Mar 31, 2025 at 4:07 PM
    Moonrman
    Hill Country, TX
  9. Mar 31, 2025 at 4:30 PM
    rnish
    Tacoma 2nd gen
    Consider using "Blue Loctite".
  10. Mar 31, 2025 at 8:04 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    @3JOH22A gave you three possibilities...which is the one you agree with and confirmed?
  11. Apr 1, 2025 at 3:15 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Shocking
    treyus30 likes this.
  12. Apr 1, 2025 at 7:02 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    I had this same issue not too long ago.
    I actually have a replacement set of bushings if you cannot find one.
  13. Apr 1, 2025 at 10:20 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Don't consider it, just do it and use it.
    I have had the same problem on my 1987 SR5 as well as on my current Tacoma. Once on the lower shock bolt, and twice on the upper. Once on the right side and again on the left. The first time was in 1994 with around 60,000 miles on it, the last about 2 years ago with 110,000 miles on it.
    The last time I used blue locktite and torqued the nuts to spec. We'll see what happens... :pray:
    Black97v6MT likes this.
  14. Apr 2, 2025 at 7:52 AM
    Tj2002
    Tj2002 [OP] Member
    Tacoma SR5 2002
    Stock
    Bolt back out.. no breakage.
  15. Apr 2, 2025 at 7:53 AM
    Tj2002
    Tj2002 [OP] Member
    Tacoma SR5 2002
    Stock
    what are the torque specs for those?
  16. Apr 2, 2025 at 9:46 AM
    skeezix
    Colorado
    1998 Limited
    Ask and ye shall receive...
    Black97v6MT and blacktacooma like this.
  17. Apr 2, 2025 at 2:19 PM
    JJ Customs
    Jay
    NV
    When you start wondering if it is tight enough about a quarter a turn past that.
    ztwatson likes this.
  18. Apr 2, 2025 at 4:03 PM
    1 Limited Toyota
    California
    08 XRunner
    German specs read gootntight
    Black97v6MT and JJ Customs like this.
  19. Apr 3, 2025 at 11:43 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
