Rear shock alternatives to OE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frogdaddy, Aug 7, 2013.
  1. Aug 7, 2013 at 12:59 PM
    Frogdaddy
    Frogdaddy [OP] Well-Known Member
    Ga.
    2010 PreRunner SR5 DC
    Pioneer MVH-p8200 hu with XM receiver using TSS supplied shark fin cable, Mud Flap cut mod.
    Finished 60k service and found driver side rear shock leaking. Only done the weekend dirt haul on occasion. Definitely sounds too early to me. But is what it is.
    I like the stock ride (have SR5 4x2 and don't off-road) and would like something comparable but obviously last longer than the OE brand without OE prices.
    Thanks.
  2. Aug 7, 2013 at 1:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Bilstein HD's :cool:
  3. Aug 7, 2013 at 3:17 PM
    Frogdaddy
    Ga.
    Very nice. Thanks.
  4. Aug 7, 2013 at 5:29 PM
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    If remember correctly if you buy oe shocks as replacments they come with a life time warranty on the part only, but it doesn't apply to the oe bilstien
  5. Aug 7, 2013 at 5:36 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Stock length bilstein 5100 holds a lifetime warranty for ~$100 a pair.
  6. Aug 7, 2013 at 6:10 PM
    Frogdaddy
    Ga.
    To clarify, the stock OE shocks have no warranty past the factory warranty, correct?
    Yet, another set or new set of OE has a lifetime warranty?
  7. Sep 7, 2013 at 1:56 PM
    Frogdaddy
    Ga.
    Pugga, thanks for suggestion. Put new HD's on today. $130 for two at shockwarehouse.com Stiff getting them on. I need floor jack to do a little manipulating. FYI, if anyone ever breaks off the top tip that stops the piston from spinning as you loosen, take a razor and cut the top boot off, then hold with vice grips or similar wrench, then loosen nut. OE shocks on my SR5 did not have a hex insert but you can use an adjustable to hold the top from spinning(if you don't break). Grommets on new shocks were wide making lining up difficult, used a little silicone spray and slid in nice. Took for a spin, noticeably stiffer truck feel from OE set and rides nice. Still can't believe slight leak at 60k. Oh well. Thanks again.
  8. Sep 7, 2013 at 2:20 PM
    Pugga
    Massachusetts
    Shocks typically won't be covered under warranty since they are considered a wear item. Dealers might replace them under warranty if they blow out say in 5k miles because there was obviously a defect (you'd still have to argue that I would guess). Some shocks might have a warranty through the manufacturer but Toyota wouldn't warranty a set of shocks.
    Hopefully those HDs work out for you. People on here seem to like them. My shocks didn't have the hex insert either, you were supposed to use a crescent wrench on the top nub to hold the shock from spinning. I ended up cutting mine off because they were corroded on and I was getting impatient dealing with the crescent wrench.
