Rear Shock Bilistein Placement
Discussion in 'Suspension' started by trailmaster308, Jan 25, 2009.
  1. Jan 25, 2009 at 7:27 PM
    trailmaster308
    trailmaster308 [OP] Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    Hey guys. I have finally gotten all my 3" kit parts ordered. I have my 2" AAL from toytec with rear 5125's and my front Toytec adjustable complete coilovers will be here Wednesday.
    My question is for the rear 5125's. They have a bracket at the top of the shocks that I am not sure which way the install goes. Is the first picture correct or the second one?
  2. Jan 25, 2009 at 7:29 PM
    trailmaster308
    Louisiana
    And of course I didn't spell Bilstein correctly :(
  3. Jan 25, 2009 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I really dont think it matters.
  4. Jan 26, 2009 at 7:04 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Bilstien has a specific 5100's direct replacement for your truck - no stem/loop adapter needed. What you received was a generic 8.5" or 10" travel shock it looks like. The vehicle specific 5125's with the added length for lift have a stem top/bushing bottom from the factory. I would ask for those instead...!
    The adapters tend to come loose after time and you dont know what valving you received with the universal 5100's
    Here is what the kit from Bilstien looks like-
  5. Jan 26, 2009 at 9:17 AM
    trailmaster308
    Louisiana
    The shocks I got have 5125 on the shocks, but your saying i got the generic 5125's and not the model specific ones?
  6. Jan 26, 2009 at 9:55 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    i just got my 5100s and they dont have that bracket.very easy to install.about 10 min a side.
  7. Jan 26, 2009 at 10:02 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I bought my 5125's from toytec, and mounted them like picture #2.
  8. Jan 26, 2009 at 10:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    So the 5125's that Toytec sells are "generic" or "Vehicle specific"??
  9. Jan 26, 2009 at 12:00 PM
    trailmaster308
    Louisiana
    I called Toytec and said I wanted the 5125's for the rear. What you see in the pictures above from my 1st post is what they sent me. The shocks came in Bilstein boxes and have Bilstein 5125 etched in the shock. Not sure what that means but it says 5125 on the model on the shock itself.
  10. Jan 26, 2009 at 12:45 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    It appear that what Downsouth Motorsports was conveying is that the 5125's that you receive are not specific to the Tacoma. If they were designed for the Tacoma they would not have the loop on the top of the shock, instead there would be a stem on the top of the shock. Valving is also more then likely not specific to your app.
    As for the way to install the shock, you should install it as shown in the second picture. The geometry just wouldn't make sense if you installed the shock as shown in picture one. When the axle is moved upward, The shock would not be able change angle causing it to bind.
  11. Jan 26, 2009 at 1:00 PM
    trailmaster308
    Louisiana
    So do ya'll think i should send them back? Or will I be ok to go with what I bought?
  12. Jan 26, 2009 at 1:02 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Im running 5125's from toytec, they ride great, and perform awesome offroad.
    The reason I went with these is because toytec specializes in toyota lifts. I am confident that they would sell me a shock that works good with the truck. And it does.
  13. Jan 26, 2009 at 1:04 PM
    Lakeside, Ca. 92040
    This is Sonny
    You will be fine...
    The 5125 series shocks are valved 255 over 70 and that is a universal valving and it will work fine....
  14. Jan 26, 2009 at 1:07 PM
    trailmaster308
    Louisiana
    Thanks guys!
  15. Feb 6, 2009 at 6:27 PM
    hsc001
    hsc001 Well-Known Member
    laurel, Maryland
    08 TRD off road lifted
    BHLM, 3" toytec coilovers, blacked out billet grille, hella 500's behind grille, volant CAI, Dual flowmasters 40's, HID, DTLT
    i just got a set of Bilstein 5125 shocks for the rear. I also got the procomp eye to stem converstion kit. The problem i am having is the stud of the procomp converstion is 5/8th and my stock shock stud is 3/8th. My question is how do i get the converstion to fit??? Do i have to drill out the stud mount hole? Or did i just get the wrong converstion kit? Please some one help!!
  16. Feb 7, 2009 at 2:17 PM
    trailmaster308
    Louisiana
    Your 5125 tops do not look like mine in the pictures? I pulled the rubber bushings out of the top and the bolt went through. For mine it was a direct bolt.
  17. Feb 8, 2009 at 11:48 PM
    hsc001
    laurel, Maryland
    no my 5125 tops look just like yours in the pic, but i didnt take off any rubber bushing. i just figured that since the stud of the converstion kit was so much bigger then the stud of the stock shock that it wouldnt fit. I will take a second look.
  18. Feb 9, 2009 at 7:41 AM
    trailmaster308
    Louisiana
    Yes the new threaded stud is much bigger than the stock one. However, the stock one runs through a rubber bushing and the rubber bushing is the same size as the new 5125 stud. Just remove the rubber bushing and the new 5125 stud fits perfect through the holes.
  19. Feb 9, 2009 at 8:05 AM
    hsc001
    laurel, Maryland
    damn, i wish you would have said that sooner, i sold my 5125's to a friend, guess ill buy those back from him.thanks for the info thou.
  20. Feb 9, 2009 at 8:51 AM
    trailmaster308
    Louisiana
    Sorry bro. It was the weekend and the weather here in Louisiana was awesome. Was lost on some back roads on my motorcycle. :D
