Rear Shock bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chefboy, May 12, 2022.
  1. May 12, 2022 at 9:32 AM
    Chefboy
    Chefboy [OP] New Member
    Sage
    2003 Tacoma Xtracab Prerunner 2WD
    I have a 2003 Toyota Tacoma Prerunner Xtracab 2WD, I need help finding this part for the Rear Shock Absorber, it’s the bolt that holds it onto the leaf spring seat, The guy told me the bolt broke off in the leaf spring seat but I stuck a screwdriver and it doesn’t feel like it. I think I just need the bolt. If anyone has any ideas lmk.
  2. May 12, 2022 at 9:42 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    catskill.joe, Bivouac and Key-Rei like this.
  3. May 12, 2022 at 9:59 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    They are m12x1.5x30. They have a big fender washer too. The bushings are the harder thing to find.
    Key-Rei likes this.
  4. May 12, 2022 at 10:12 AM
    Chefboy
    Sage
    Would I need the bushings if I was to put on new shocks? I have some Bilsteins I want to put in and they have the bushings, I would still need the washer tho huh
    Wulf likes this.
  5. May 12, 2022 at 10:33 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    My 5125's rear shocks came with 2 washers (one for the top and one for the bottom bolt).
  6. May 12, 2022 at 11:41 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your sure they are 1.5 maybe they changed in the newer models !
    Mine are 1.25 maybe yours were changed?
  7. May 12, 2022 at 2:03 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I'm pretty sure. I have a thread size tester thing I can go run into the stock mount this weekend..
  8. May 12, 2022 at 2:24 PM
    Bivouac
    If the op orders them from Toyota by the part number they should get the correct ones
  9. May 12, 2022 at 3:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    OP could've gone to the store, remove other bolt to bring inside said store, and bought a pair of new ones after finding the correct length and size.
    :burp:
    Kevins60 and Sharpish like this.
  10. May 12, 2022 at 4:20 PM
    Bivouac
    Depends where He lives! I don`t have any local sources for most metric bolts Why I filled a Bolt bin.
    Kwikvette[QUOTED] likes this.
  11. Aug 6, 2022 at 10:18 AM
    catskill.joe
    catskill.joe Well-Known Member
    04 Red TRD Off Road - XtraCab - 6 cyl - Manual
  12. Aug 7, 2022 at 6:40 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Over the years I've had a few of my rear shock bolts come completely out. I finally used some blue locktite on them and torqued them to spec. This has happened on both left and right sides, and on both the top and the bottom bolts. YMMV.
    catskill.joe likes this.
