Rear shock clearance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, Oct 12, 2024.
  1. Oct 16, 2024 at 7:53 AM
    #41
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    What are the tires you have on there right now?
  2. Oct 16, 2024 at 7:58 AM
    #42
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    245/85r16 sumitomo
  3. Oct 16, 2024 at 8:12 AM
    #43
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Are they a commercial truck tire?
  4. Oct 16, 2024 at 8:13 AM
    #44
    Neticstacoma
    No it’s not actually these tires are used for sand .. Sumitomo Shaheen
  5. Oct 16, 2024 at 8:31 AM
    #45
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Interesting... So those tires are actually designed to look like that... How old and how many miles are on your tires?
  6. Oct 16, 2024 at 8:48 AM
    #46
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Out of curiosity, since you're running pretty common overseas Profender shocks/coilovers, english seems maybe like a second language (no offense, better than most i read here) and you have sand specific tires... are you in the UAE? That kind of changes what we'd recommend, the US doesn't have much terrain like the dunes out there.
  7. Oct 16, 2024 at 10:04 AM
    #47
    Neticstacoma
    About a year am not sure exactly how many km maybe 40k km actually they are still in a good shape but they look bad in those pictures cus they were dusty
  8. Oct 16, 2024 at 10:05 AM
    #48
    Neticstacoma
    your guess is sharp yes I am from UAE
    TegoTaco and Speedytech7[QUOTED] like this.
  9. Oct 16, 2024 at 10:14 AM
    #49
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Cool, it's unfortunate you didn't get asked and/or inform others what kind of tires they actually are because they don't need to be replaced at all it seems...
    Your "off road" is actually Sand Dunes. I'm not sure if Duratrac's would be the recommended tire for this off road application?
    This suspension question/thread went incorrectly way off topic because of some incorrect assumptions....
    hyrule_trd likes this.
  10. Oct 16, 2024 at 10:20 AM
    #50
    Neticstacoma
    yes I noticed that people didn’t know what kind of tires am running but still with a lift they don’t look that cool so later I am planning to replace them
  11. Oct 16, 2024 at 11:04 AM
    #51
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Now it all makes sense lol!
    jackn7 likes this.
  12. Oct 16, 2024 at 7:58 PM
    #52
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Are those giant, inline compression stops around the shafts of those rear shocks? If so, I have not seen them that big before.
  13. Oct 16, 2024 at 10:18 PM
    #53
    Neticstacoma
    Yes they are
  14. Oct 17, 2024 at 5:25 AM
    #54
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    سَلَام
    It's hard to tell from just the pictures you've posted but your leafs do look pretty flat, especially for an empty bed.
    f you're in the UAE, there is a very large supply of wrecked Tacomas and 4Runners, which means a large supply of wheels and leaf packs that will fit your truck. I don't know if there are "You Pick" junkyards there, but if so, you may be able to find a 2nd gen Tacoma with leaf packs (common decent aftermarket that wasn't worth pulling for individual sale) for pretty cheap that will work for you while you figure out what to go with for your full setup.
  15. Oct 17, 2024 at 5:36 AM
    #55
    Neticstacoma
    W alaikum al salam
    Correct there are many junkyards with tacoma parts but as a temporary solution I added one extra leaf for both sides till I figure out what leaf pack am gonna buy
    jackn7 likes this.
  16. Oct 17, 2024 at 6:49 AM
    #56
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    Originally, I was going to say a new leaf spring pack (whichever you choose) with lift through arc, increases the uptravel range at the shock by increasing the distance between the rear bump stop and frame strike point.
    An add a leaf increases leaf strength and lift, and lengthens the shock in doing so, but does not add much if any arc.
    Most speed over desert guys want more rear uptravel over stock and new leaf packs with lift provides it.
  17. Oct 17, 2024 at 12:23 PM
    #57
    Neticstacoma
    Definitely am gonna get a new set of leaf packs but still didn’t decide which one. Here in Dubai we have some dealers like ARB, Ironman, Dobinsons, Icon and some others but I am not sure if Tacoma’s leafs are available with them
  18. Oct 17, 2024 at 12:29 PM
    #58
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    All of those companies make packs for the Tacoma - ARB is probably the #1 global producer of Tacoma packs (under the OME line) by volume. Icon leaf packs are very highly regarded, but any of them will do. You may want to talk to people locally about what specific packs are common for the kind of wheeling you do - high speed loose dunes are not extremely common runs in North America. Maybe check in thr California regional forums.
  19. Oct 23, 2024 at 7:51 AM
    #59
    Neticstacoma
    Update
    As I said I drive the car daily on highways I noticed that the car is very stiff in the back I don’t know maybe from the extra leaf I added.. any thoughts guys?
  20. Oct 23, 2024 at 8:01 AM
    #60
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    As expected. Stronger leafs with the same weight in rear = stiffer ride. No way around that.
    Solution: add weight. At least a few hundred pounds of anything. Chunks of steel, bags of sand, bricks, whatever.
    Edit: Use anything for ballast temporarily to figure out how much weight is needed for a comfortable ride. But in the long term, use sand bags or permanently-fixed (welded or bolted) ballast.
    In a serious accident, unsecured solid objects in the rear are likely to become projectiles & could penetrate the rear window glass & enter the passenger cabin.
