rear shock extenders
Discussion in 'Suspension' started by pudge151, Apr 28, 2011.
  1. Apr 28, 2011 at 5:31 PM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    does anyone have these? i am not lifted i have the rear TSB, would there be any real benefit to having these? i have had my suspension both bottom and top out while on the beach on vacation
  2. Apr 28, 2011 at 5:35 PM
    Stopko
    Stopko Active Member
    Kevin
    Homestead iowa
    O7 TRD off road Tacoma
    Rpm hood struts, vent visors,hood protector, weather tech floor mats, clarion NAV/DVD, Sat radio, 10” clarion Sub, Two 500 watt MB Quarts Amps, 2 sets of alpine component speakers, k&n filter, smitty built light bar, 2 6” kc day lighters, 2 8” pro-comp Lights, 3 inch spacer lift, AAL in Rear, Paint matched grill, MB Torque 16X8 Wheels, 285/75/16 BF Goodirch AT KO's, 35% tint all around. Ton no pro bed cover, Flow master dual exhaust, Blacked out emblems, Stubby antenna, Scan gauge Green Stuff brake pads.
    Just buy real shocks, there is a weak link using them things.
  3. Apr 28, 2011 at 6:28 PM
    pudge151
    Sean
    Connecticut
    i have billstein 5100's
  4. Apr 28, 2011 at 8:15 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The idea with those is that if you lift the rear 2-3", the extenders will allow your rear axle to drop as much as it would pre-lift; normal length shocks will be fully extended and stop the droop of your rear tires before the leafspring want to stop drooping, after lifting.
    For example, let's just say your rear tire will drop 10" at stock. Then you lift it 3", now your rear tire will drop 13", but the stock shock only wants to drop 10" still = add the extender and now the stock shock will drop to the full 13".
    I've never heard of an extender breaking on a Taco shock (doesn't mean it hasn't/won't happen). The design seems stout enough for all but the most rugged users. It does look funny IMO, but is a real cheap alternative to buying longer shocks.
    If you're not lifted, you will not gain any benefits. Actually, you will be making your stock shocks bottom out 2" prematurely.
    RadTad likes this.
