Rear Shock Help
Discussion in 'Suspension' started by mnudo200827, Jul 11, 2010.
  1. Jul 11, 2010 at 6:01 PM
    mnudo200827
    mnudo200827 [OP] Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    I am going to be getting custom Alcan Springs with 4" of lift pretty soon. My question is what shocks do i need that allow full up and down travel. And that give a good ride, maybe better than the stock TRD shocks if thats possible. I do plan on doing off roading and trail riding and some dessert stuff, nothing to crazy but like to have too much fun sometimes:D. I am probably going to want some remote resivior shocks. I am just confused by all the different types and brands valving etc... I see a lot of people with the 5100 and 5125 but i am thinking i want something a bit better, but i am open to all brands...Icon,Fox,King,Billys...Thanks for the help.
  2. Jul 11, 2010 at 6:07 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    if you go billys 5125's is what you will need the 5100 are only good to about 2" of lift. to figure out which 5125's you need either measure yourself or ask people you run the same setups
  3. Jul 11, 2010 at 6:10 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Fox, Icon, King. Pick your poison. I went with fox and all pro leafs.
  4. Jul 11, 2010 at 6:12 PM
    mnudo200827
    Michael
    Corona, CA
    ya they seem to be really good, just need help with the size in terms of up and down travel, thats what i am confused about, with the 4" lift in the rear.
  5. Jul 11, 2010 at 6:12 PM
    08pretaco
    az
    i guess we should also talk about budget! those are great if your looking to spend and billys are great for a budget
  6. Jul 11, 2010 at 6:14 PM
    08pretaco
    az
    once you get the leafs you need to go out and measure your travel. install the leafs then make the rear flex and articulate without the shocks and then do your measuring there. if you leave the shocks in there with the lift you wont get full measured reading because of the lack of flex...at least thats how i would invision doing it, if thats wrong someone will chime in
  7. Jul 11, 2010 at 6:17 PM
    mnudo200827
    Michael
    Corona, CA
    well i already spent...
    1) $1000 on Camburg Spindles
    2) Icon Coilovers
    3) $1000 on KM2's
    4) $700 on rims
    5) $600 on Alcan Springs
    so budget, shbudget, i want the best that will work for me
  8. Jul 11, 2010 at 6:19 PM
    08pretaco
    az
    oh i didnt link up the other thread to this one sorry. id say fox if you got the coin, fox shit looks sexy and performs very well!
  9. Jul 11, 2010 at 6:19 PM
    08pretaco
    az
    oh and btw your going to love the spindles
  10. Jul 11, 2010 at 6:20 PM
    mnudo200827
    Michael
    Corona, CA
    ya i cant wait to get every thing on, its sitting all in my garage, it bugging me haha
  11. Jul 11, 2010 at 6:24 PM
    08pretaco
    az
    you doing the install?
  12. Jul 11, 2010 at 6:26 PM
    mnudo200827
    Michael
    Corona, CA
    yep everything but the tires and rims, going to take it to a shop, just worried about the spindles kinda, never done this before, havnt really read into installing them, i just dont know if i have to get new seals for bearings and regrease, but i guess i will find out with some research.
  13. Jul 11, 2010 at 6:28 PM
    08pretaco
    az
  14. Jul 11, 2010 at 6:29 PM
    mnudo200827
    Michael
    Corona, CA
    so its still all sealed when i take it apart?
  15. Jul 11, 2010 at 6:31 PM
    08pretaco
    az
    ya the whole the assembly comes out as a whole and you transfer the whole over to the new one
  16. Jul 11, 2010 at 6:33 PM
    mnudo200827
    Michael
    Corona, CA
    alright cool, nothing to worry about now haha
  17. Jul 11, 2010 at 6:35 PM
    08pretaco
    az
  18. Jul 11, 2010 at 6:37 PM
    mnudo200827
    Michael
    Corona, CA
  19. Jul 11, 2010 at 10:56 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Yep, what he said. Flex it out completely with no shocks on. Measure the distance between the shock mount points at full droop and full tuck.
    You might want to add an extra inch or two to each of your measurements because those springs will probably get a bit more flexy when they break in.
    Once you have this measurement you can get the perfect shock from any of the top companies. Don't waste any time looking for "shocks for Tacoma with 4" lift". Just buy the exact length you need in the brand you like.
    If it is hard to find a shock that hits that "sweet spot" within your measurements, then you should try and address the droop measuremnet more, and correct the tuck issue by getting bigger/longer bumpstops to limit the tuck travel.
  20. Jul 12, 2010 at 11:07 AM
    mnudo200827
    Michael
    Corona, CA
    how do you guys suggest i flex it out? With a jack i guess.
