Rear shock leaking oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, May 17, 2020.
  1. May 17, 2020 at 9:15 AM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Went offroading a few days again, noticed when I got home that my rear shock was leaking. I’m probably going to buy some OME suspension in the next month or so. Should I replace that shock with a $30 monroe in the time being?
  2. May 17, 2020 at 9:17 AM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    If it's your daily then yea I would but, if you only drive it occasionally then I think it could wait till you get your new suspension.
  3. May 17, 2020 at 9:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just replace it with an OME kit.
    No use throwing away money but if you're so inclined just do it; your truck and your money and a quick 5 minute job.
  4. May 17, 2020 at 10:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't tow, don't drive hard, don't load the bed and you'll be fine.
    Half the folks around here are driving with shocks that are dead (from normal wear) and don't even know it.
  5. May 17, 2020 at 10:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This is very true!
    Many people will say "my shocks lasted me 80-100k miles"
    Just because they didn't break doesn't mean they don't warrant being replaced. The oil breaks down overtime as it goes through "hot" and "cold" cycles.
    Maybe the guy that said I'm wasting money if I don't keep my shocks on until 100k miles will chime in. :popcorn:
    High Noon likes this.
  6. May 17, 2020 at 10:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    We'll just go ahead and get this out of the way then................
  7. May 17, 2020 at 10:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If I can "Like Very Much" I would.
  8. May 17, 2020 at 12:44 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    I don’t need to jack the truck up to replace the shock do I? Just zip off the 2 nuts and pull it out?
  9. May 17, 2020 at 12:48 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    depends on how much its leaking, if its just oily residue you can go on it for along time more with reduced performance
  10. May 17, 2020 at 12:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Correct.
    2 minute job if tools are already out.
  11. May 17, 2020 at 1:06 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    It leaked a whole lot. It’s not dripping anymore so that leads me to believe that all or at least most of the oil is gone. I think I’m just going to throw a cheap monroe on there for the time being.
    BillsSR5[QUOTED] likes this.
  12. May 17, 2020 at 1:22 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    I actually tore a shock in half (over extension). Drove truck for a few weeks with only one shock. It was fine, save your money for your long term shocks. Only thing you’ll notice is back end bounces around a little longer going over bumps.
  13. May 17, 2020 at 1:30 PM
    BillsSR5
    bill
    2014 SR5
    good idea, just get the cheapie for now install is a piece of cake
  14. May 17, 2020 at 1:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    Waste of time and money if you are going to replace in a month anyway.
    Kwikvette likes this.
  15. May 17, 2020 at 2:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep!
    Would rather take a couple of buddies out for In N Out, or Whataburger in your case, than buy a crappy shock I'll toss away.
  16. May 17, 2020 at 4:29 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    I went ahead and replaced it because it was pretty bouncy and had a lot more body roll than usual. Ill keep the cheap shock for a spare for my dads 3rd gen 4runner or something.
