Rear shock length difference & why it matters
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Feb 29, 2020.
  1. Feb 29, 2020 at 7:00 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I have been looking around for shocks & came across how 1st gens have a longer rear shock on the passenger side. Obviously there is a reason (someone posted it is to do with the parking brake) & an adjustment was made. So in my searching I found that most? all? brands except KYB do have rear L/R specific. Why is KYB the exception? Or is there potential, no matter how slight, for some fallout from having rear shocks of equal height installed? Again, obviously there's a reason this L/R dif was put n place to start with & is still the norm.
    Edit - Hey, I kind'a got right to the point :)
  2. Feb 29, 2020 at 7:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shocks like the Monroe work with the stock leaf pack, which will be limited in their extended and collapsed lengths.
    You're not getting Monroe's to tear it up on the trails.
    With that being said, its a budget shock that'd be cheaper to make if they were both mirrored.
    The more expensive the shock, the more specific role it has to play.
    Black DOG Lila and Hobbs like this.
  3. Feb 29, 2020 at 7:15 PM
    Kristi with a K
    Western MA
    Not sure I follow. It sounds like you are stating that the more expensive shocks would be more likely to be L/R specific?
    cruiserguy, Hobbs and Black DOG Lila like this.
  4. Feb 29, 2020 at 7:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    More like, the more expensive shocks such as Bilstein, Fox, King, etc. have the role of damping road conditions in a harsher environment IE offroad.
    Collapsed and extended travel lengths become an important factor here as well as damping and since the shock mounts are at different lengths, the shocks are made for said application.
  5. Feb 29, 2020 at 8:02 PM
    Kristi with a K
    Western MA
    So why would Toyota put L/R specific shocks with standard springs, as on my truck. They are still sold this way as well. Also, I realize you were just using them as an example, but this is all that came up when searching my truck on the Monroe site.
    OESpectrum Light Truck Shock Absorber 37114 Recommended OE Application -Specific Replacement
    MONROE SHOCKS & STRUTS: Premium Product Rear Left 1 VIEW
    DETAILS
    OESpectrum Light Truck Shock Absorber 37113 Recommended OE Application -Specific Replacement
    MONROE SHOCKS & STRUTS: Premium Product Rear Right 1 VIEW
    DETAILS
    Monro-Matic Plus Shock 32295 Rear Left 1
    DETAILS
    Monro-Matic Plus Shock 32294 Rear Right 1
    If stock leaf springs are limited in their extended & collapsed lengths, why wouldn't a shock that is too long put unnecessary added strain, maybe in a different way than you are referring to, on it as well?
    cruiserguy, Black DOG Lila and Hobbs like this.
  6. Feb 29, 2020 at 8:10 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    It would be interesting to know if Toyota sells two different shocks for the left and right rear on the 1st gen.
    Kwikvette and Black DOG Lila like this.
  7. Feb 29, 2020 at 8:19 PM
    Kristi with a K
    Western MA
    Yes. They do.
    Part Number: 4853109100
    Part Number: 4854109030
  8. Feb 29, 2020 at 8:20 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Now I want to measure the distance between top and bottom shock mounts and compare left and right sides to see if the distance is different.
    Thanks for getting to the point @Kristi with a K and adding to my Sunday to do list:D:thumbsup:
  9. Feb 29, 2020 at 8:21 PM
    Hobbs
    Yep…
    Ahhh... so it is a thing. You would think that the aftermarket would mirror this. I wonder how much difference there is.
  10. Feb 29, 2020 at 8:25 PM
    Kristi with a K
    Western MA
    & I have had KYB's on mine. I just put on new springs & am noticing a pinch of space in between the leaves on the driver's side. I am going to switch out to L/R specific & see if it makes a dif.
  11. Feb 29, 2020 at 8:25 PM
    Kristi with a K
    Western MA
    I think about an inch.
    Kwikvette and Hobbs[QUOTED] like this.
  12. Feb 29, 2020 at 8:26 PM
    Hobbs
    Yep…
    That sounds like a lot. I hope you get it sorted out! :thumbsup:
  13. Feb 29, 2020 at 8:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There's almost an inch difference.
    King, Fox, Bilstein and a few more do.
    Aftermarket shocks that publicly share their extended and collapsed lengths will show a difference of almost an inch between driver and passenger; you see that now as you measured the difference.
    I just think its not all that talked about until someone orders shocks that aren't generic throw aways.
    After all, these trucks are damn near 20 years old.
  14. Feb 29, 2020 at 8:37 PM
    Kristi with a K
    Western MA
    I guessed at that. OE looks like it could be 1/2 compressed? I am just doing quick looksees & of course, the toyota parts sites give up next to no specifics on the parts. Just that you need them & they are the only one who has 'em, or rather, they are going to make sure you can't double check specs before going elsewhere.
    Black DOG Lila, cruiserguy and Hobbs like this.
  15. Feb 29, 2020 at 9:04 PM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Just installed 5100s on the rear today. Longer shock goes on the passenger side. Yes the mounting distance is different on each side.
  16. Feb 29, 2020 at 9:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Really what's important is that you install the shock on its respective side.
    In the event that you do offroad, and in the event that your shocks collapse or extend to their max length, you'll be happy you put them in the correct spot.
  17. Feb 29, 2020 at 10:03 PM
    Running Board Man
    Running Board Man Well-Known Member
    Our shocks arnt straight up and down
    Theyre mounted on an angle
    If one shocks angle is steeper the one whose angle is steeper will be shorter
  18. Feb 29, 2020 at 10:12 PM
    Kristi with a K
    Western MA
    Right. My question though is, since the one that is at a steeper angle is supposed to be shorter, what happens if it is actually the same length as the other side?
  19. Feb 29, 2020 at 10:13 PM
    Running Board Man
    The one whose shock should be shorter will droop more if theyre both long
    Or
    The one whose shock should be longer would droop less if theyre both short
    Basically nothing
    Black DOG Lila likes this.
  20. Feb 29, 2020 at 10:17 PM
    Kristi with a K
    Western MA
    'zactly what I am thinking. & why I wanna switch out mine ASAP. Mine were installed before I was a DIYer. Think I might go have a talk with the mechanic who installed them. He didn't do anything wrong per se. But I should have been given the facts & the options.
