Rear shock length difference & why it matters
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Feb 29, 2020.
  1. Feb 29, 2020 at 10:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Already answered this above.
  2. Feb 29, 2020 at 10:25 PM
    Running Board Man
    Running Board Man Well-Known Member
    ... youre making a bigger deal out of it than it is, and honestly if you paid the mechanic 40 bucks to change the shocks the quicker they get that done the quicker they can move onto that 200 dollar water pump
    They wont remember putting on your shocks and they probably didnt care about one being 3/4 of an inch longer
    Black DOG Lila and Kwikvette like this.
  3. Feb 29, 2020 at 10:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Swapping the shocks over is literally a 5 minute job, including grabbing the ratchet and correctly sized socket.
    You can do this on your back without having to lift the truck or anything.
    Running Board Man likes this.
  4. Feb 29, 2020 at 10:28 PM
    Running Board Man
    Its 14mm
  5. Feb 29, 2020 at 10:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    3/8" drive if we want to get specific; 1/4" is too small to get the right leverage and 1/2" drive is overkill.
    6 wall socket for that 14mm.
  6. Feb 29, 2020 at 10:30 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I see. Whelp, I appreciate your, as well as everyone else's, input & am glad there are others who got something out of my bringing this up.
  7. Feb 29, 2020 at 10:31 PM
    Running Board Man
    Uhhh i use my 1/2 drive on 10mm bolts
    cruiserguy and Kwikvette[QUOTED] like this.
  8. Feb 29, 2020 at 10:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof
    Too easy to overtorque
  9. Feb 29, 2020 at 10:31 PM
    Running Board Man
    We need more people like you on this fourm
  10. Feb 29, 2020 at 10:32 PM
    Running Board Man
    Not if you have control of your wrist
    Black DOG Lila likes this.
  11. Feb 29, 2020 at 10:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :anonymous:
  12. Feb 29, 2020 at 10:42 PM
    Kristi with a K
    Western MA
    Ha-ha! You mean people who make bigger deals out of things than they are?
  13. Feb 29, 2020 at 10:44 PM
    Running Board Man
    Go to the 3rd gen section youll see what i mean
  14. Mar 1, 2020 at 1:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I think it comes down to just how you use your truck.
    If your out there crashing over rocks where your getting lots of flex lots of movement in the shocks I can see a inch making a difference .
    How I use the Truck if I ever got the shocks on correct if the ones I bought were different was pure chance .
    Though I do wonder if it might have something to do with the broken upper shock mounts ?? I fix all to often that I keep new ones.
  15. Mar 1, 2020 at 5:15 AM
    #35
    Running Board Man
    Sir... how do you mess up shock mounts, id beat the piss out of my truck without bumpstops (because i never had them) and be a-ok
  16. Mar 1, 2020 at 8:32 AM
    #36
    Kristi with a K
    Western MA
    Well, while we are all on the "overthhinking" train.... While I realize the easy response could be "who knows why toyota does" this or that, why did they bother installing two different length shocks (still available to purchase) on an SR5, a truck that does not come off the showroom floor intended to be beat on? They cut corners & very well could have chosen to here. That's s'alot'a shocks = $$$$.
    In the case of myself & @Wyoming09 what happens when instead of beating on the truck, you put it to work hauling wood or bricks? & while I did not have wood overflowing the bed, my guess is this could have an effect on 1. the drivers side shock getting taxed & 2. potentially the mounts 3. leaf springs? My drivers side, flat as a pancake.... sort of.... But way worser than the passenger.... Chicken or the egg.... Spring was going & affected shock? Shock was bottoming out under load & affected spring? All of this is just musing. Not my expert opinions. But I do know toyota has my truck's wimpy version of shocks available for purchase & they are l/r specific & 35.00 ish apiece. Not the typical stealer price when comparing to other brands.
    Wyoming09 likes this.
  17. Mar 1, 2020 at 8:47 AM
    #37
    Wyoming09
    New Tripoli Pa
    Super Springs
    Myself I never broke any The vehicles just seem to appear this word of mouth advertisement is brutal
    It just might have something to do with our lovely climate and the use of liquid brine.
  18. Mar 1, 2020 at 8:49 AM
    #38
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Overloading will not damage the suspension.
    Per say. BUT
    Hitting bumps and pot holes while overloaded and riding on leaf bump stops takes a toll on the leafs, hangers and bushings.
  19. Mar 1, 2020 at 8:50 AM
    #39
    Kristi with a K
    Western MA
    The broken mounts you are referring to are ones you fix at work, on other peoples’ trucks, yes?
    Wyoming09[QUOTED] likes this.
  20. Mar 1, 2020 at 8:55 AM
    #40
    Wyoming09
    New Tripoli Pa
    Super Springs
    Yes Kristi that is correct but it is not work!!
    It is just for fun Work would be billed far to expensive for most to pay on fixing aged Toyota Vehicles
