Rear Shock Length (Icon leaf option 2)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mctechhweng, Aug 28, 2022.
  1. Aug 28, 2022 at 9:41 AM
    mctechhweng
    mctechhweng [OP] Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    Hi All.
    Need some help here. Installed Icon leafs with option 2 and measured a lift gain of 2.75" from before (Have camper shell, sliders, lots of sound deadener, stock springs).
    What would I order for shocks? Can I just get the OME shocks (60091) from this kit? https://**********/products/ometac-2gen-2-5stc?_pos=1&_sid=38d08f10b&_ss=r
    How would you go about measuring what you need?
  2. Aug 28, 2022 at 10:44 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    With stock shock mounting locations your limiting factor is going to be compressed total length of the shock.
    Get out the tape measure:
    1. measure center of the bolt on the lower shock mount to the bottom surface of the upper shock mount.
    2. measure distance from top of bump stop to frame
    3. subtract # 2 from # 1
    4. subtract expected squish of bumpstops from # 3.
    There is your longest collapsed length of the shock.
    The OME 60091 shocks wouldnt have a problem working as they will work with stock leaf packs no prob. That stated you are probably leaving some on the table with that choice as your new leaf pack is likely quite a bit thicker and wouldnt utilize the full collapsed length of that shock. Something like a Bilstein 5125 part num 33-230337 might be better but you will have to confirm the longer collapsed length will work via the measurements above.
  3. Aug 28, 2022 at 12:03 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Subscribing. I'll be picking up this leaf pack soon as well and need to confirm if I should keep my TRD Bilstein 5160's or swap to something else for better travel. I assume I'll just have to install, measure, then figure it out but hoping this thread may save me some time and hassle.
  4. Aug 28, 2022 at 4:34 PM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    I’m assuming I take the measurement of frame to bump stop with the tires off the ground?
    What do ppl normally do if relocating shock mount? I’ve seen where they put it sort of straight above & in line with axle. Anything less substantial?
  5. Aug 28, 2022 at 5:11 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Right now I have Deaver stage 2 gave me 2.5 inches of rear lift I have ome BP 51s but I replacing them with the 60091for the meen time till dobinsons ims rear shocks are back in stock. And they will be fine. I had the 60091 shocks when I had ome Dakar leafs that gave me around the same lift heights.
  6. Aug 28, 2022 at 5:35 PM
    nd4spdbh
    SoCal
    The calculations will give you the same final figure regardless if the suspension is fully drooped or at normal ride height.
  7. Sep 21, 2022 at 10:58 AM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    I'm running stock bump stock right now. I've been thinking about replacing it but I hadn't decided with what I would replace it. Any suggestions?
