Rear Shock Lower Bolt Specs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GSRoland, Jan 11, 2021.
  1. Jan 11, 2021 at 6:25 PM
    GSRoland
    GSRoland [OP] New Member
    2017 Tacoma OffRoad
    AT Overland Habitat, ARB Front Bumper, ARB Skid Plates, Mobtown Offroad Sliders, ARB/OME Suspension Kit
    Did the work today replacing a missing bolt, so figure I would try and save someone time in the future. 17mm wrench/socket for OEM
    Flange Bolt: M12 1.25 x 60mm Toyota Part No. 9155211260
    Washer: M12 Toyota Part No. 9462251200
    Flange Nut: M12 1.25 Toyota Part No. 90178A0057
    Torque: 43 lb-ft
    Toolndie7 and tonered like this.
  2. Jan 11, 2021 at 6:36 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    Thanks for the update, where did you get the torque spec for the lower shock mount? I have been torquing them to 74 ft lbs. Sounds like the information I had may be incorrect.
  3. Jan 11, 2021 at 8:24 PM
    GSRoland
    2017 Tacoma OffRoad
    Interbeing[QUOTED] likes this.
  4. Jan 11, 2021 at 8:30 PM
    Interbeing
    Austin, TX
  5. Oct 30, 2022 at 3:31 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I compress the shock. But I think you need a new one first. o_O
  6. Mar 22, 2023 at 8:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks for the info! Needed these as I messed up mine when I originally pounded in some 5125s.
    Can also be sourced from belmetric.com :
    Bolts:
    Washers:
    05 4x4 likes this.
  7. May 6, 2023 at 1:56 PM
    05 4x4
    05 4x4 Well-Known Member
    @tonered sorry to keep blowing you up. Your link is to an "extra fine" thread. Is that what is stock, or is that fine thread? I cant find a nut for that extra fine thread. Thanks!!!
  8. May 6, 2023 at 1:59 PM
    05 4x4
    Looks like it is the same thread as stock actually. I guess I could just use my stock washer and nuts?
  9. May 6, 2023 at 2:22 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No worries!
    Yes. Same thread as Stock. When we bought them, one of the nuts had to be ordered in a different plating (nickel versus cad).
    M12 x 1.25 doesn't seem extra fine to me. Just a classification though.
    :cheers:
