Rear shock mount bolts - local source
Discussion in 'Alaska' started by fergyz, May 9, 2024.
  1. May 9, 2024 at 10:32 AM
    fergyz
    fergyz [OP] Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    I had a shock fail last night. I replaced the broken one.... tried replacing the other shock - things went south. Dealership does not have the bolts. can anyone point me in a direction to source new ones locally?
  2. May 9, 2024 at 10:36 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I'm not in AK but have been in this situation before. In case you don't get any quick replies - any halfway decent auto parts or home improvement store should carry a grade 8 bolt that is the same thickness. Wouldn't hurt to call beforehand though just to make sure. Also take the OEM bolt as a reference if you can. It doesn't have to be an exact match, but if the new setup is a little longer that shouldn't hurt anything. Just be sure to get a new nut and washer as well if the threads don't match or the old components can't be reused.
  3. May 9, 2024 at 10:41 AM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    Maybe try Fasteners and fire equipment, if not them they can lead you in right direction. & I do have set of Off-Road shocks. That I might get rid of if needed.
  4. May 9, 2024 at 10:52 AM
    fergyz
    49th State
    06' DBC 4x4 6spd
    Completely a solid option. Just ended up with a little tunnel vision over the situation.
    drizzoh[QUOTED] likes this.
  5. May 9, 2024 at 10:55 AM
    fergyz
    49th State
    06' DBC 4x4 6spd
    the parts guy at the dealer did mention trying F&F..... i will call them. I have the replacement shocks on hand - wasn't expecting the "good" shock rubber bushing to have itself seized to the factory bolt. Wasn't even going to try burning out the bushing in my driveway.
  6. May 9, 2024 at 11:17 AM
    AK Dudeman
    DCBLB OR MGM 22
    Every Time im there the dealer, doesn't have I'm look’n for either. Good luck.
    musicisevil likes this.
