Rear shock nut problem
Discussion in 'Downsouth Motorsports' started by DaveEli, Jun 8, 2013.
  1. Jun 8, 2013 at 11:46 AM
    DaveEli
    DaveEli [OP] Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Just recieved my Icon VS 2.0 (CB# 2018) rear shocks. The nylock nut will not thread on to the shock. I could probably force in on but I don't want to damage the threads. It barely goes on half a turn. Any suggestions?
  2. Jun 8, 2013 at 12:50 PM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    Ya, don't force it on. Where did you order from? Worst case bring the shock to your local hardware store and check a few lock nuts see if anything will thread on and work. If not, then the shock end may be bad.
  3. Jun 8, 2013 at 2:27 PM
    DaveEli
    David
    Virginia Beach
    Got them from Downsouth Motorsports. They are closed on weekends of course.
  4. Jun 8, 2013 at 2:31 PM
    TRDFORME
    TRDFORME Well-Known Member
    98 trd 4x4 limited
    Ace hardware has a good bolt and nut selection. Check them out
  5. Jun 8, 2013 at 2:35 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Check the nut from the other shock you got and see if that one works. If it does, then it's just the nut you can get at any hardware store.
    If the other doesn't go on, I would contact DSM and see about getting a replacement
  6. Jun 8, 2013 at 2:52 PM
    DaveEli
    David
    Virginia Beach
    Neither nut works on either shock. Wonder if I got bad nuts. God that sounds bad.
  7. Jun 8, 2013 at 3:04 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    They may have just had the wrong one's put in then. Which is better than bad threads. Take a shock to the store with ya. If your in the middle of Install, it's ok to drive w/o them on the rear. May be bouncy, so just take it easy.
    I believe they are M12, just can't remember the pitch on it.
  8. Jun 8, 2013 at 4:04 PM
    DaveEli
    David
    Virginia Beach
    Guess I will be going to Fastenal on Monday. Hope that does it.
  9. Jun 8, 2013 at 4:17 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Sounds like to me they are the wrong thread pitch.
  10. Jun 11, 2013 at 7:18 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Good morning Dave,
    Did Icon provide the wrong nuts, or is the stem on the shock threaded incorrectly?
    Micah
  11. Jun 12, 2013 at 4:29 AM
    DaveEli
    David
    Virginia Beach
    I talked to Neil at Downsouth. He called Icon and they said I could either get new shocks or I could try to tighten the nuts and see what happens. I decided to tighten the nuts down on the shocks. They went on tough for the first couple of turns but then loosed up. I guess they were just tight, but I was afraid of ruining the threads. I didn't want to do it till you guys and Icon said I wouldn't be responsible for ruined threads. All well that ends well. I want to thank you guys, and Icon for great customer service. Dave
  12. Jun 12, 2013 at 4:39 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Fixed it for you :D
  13. Jun 12, 2013 at 5:01 AM
    DaveEli
    David
    Virginia Beach
    It's good not to have bad nuts!!!
