Rear Shock Options for 6" Fabtech Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grippy, Feb 28, 2022.
  1. Feb 28, 2022 at 10:27 AM
    grippy
    grippy [OP] Active Member
    Tempe, AZ
    05 Tacoma 4WD
    Hi everyone. My fabtech rear shocks have blown out after 10+ years on my Tacoma. It is a 6" lift. How do I know which shocks (other than Fabtech) will work properly on a 6" lift? Is there a certain length measurement I should look for?
  2. Feb 28, 2022 at 11:39 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    I assume shocks for any 6" lift would work for you application.
    If you want to be sure, though, you should measure the expanded and collapsed lengths of your current blown shocks and use those measurements for ordering
  3. Feb 28, 2022 at 11:46 AM
    grippy
    Tempe, AZ
    05 Tacoma 4WD
    Sounds good. Does anybody have any experience with different brands i.e. one being better than the other?
  4. Feb 28, 2022 at 11:48 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    I used to have a Fabtech 6" on my truck. When the Fabtech rears gave out I replaced them with the Fox rear shocks that some with the BDS 6" lift. They worked fine, and I didn't really notice a difference in ride quality from the Fabtech shocks
  5. Feb 28, 2022 at 1:03 PM
    grippy
    Tempe, AZ
    05 Tacoma 4WD
    Good to know. Has anyone out there switched to reservoirs from non-resi lift shocks? Is it noticeable or even worth the large $$ increase?
