Rear Shock Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Range 44, Sep 29, 2010.
  1. Sep 29, 2010 at 6:44 AM
    Range 44
    Range 44 [OP] Well-Known Member
    Georgia
    2008 FJ TTE
    I have a 2011 TRD OR DC PR, I wanna run 5100's up front @ 1.75 with TSB done in the rear and a 1.5 AAL. Do I need to replace the rear shocks or can I use the factory Billies? Also, has anyone used the "Taco Lean" spacer from Toyotec?
  2. Sep 29, 2010 at 9:29 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    You could probably get away with the factory shocks in the back, but if you really stretch it out offroading, the shocks would likely max out
  3. Sep 29, 2010 at 9:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You really should swap the OEM shocks too. They are not up to the task of dampening the TSB spring pack with an AAL.
  4. Sep 29, 2010 at 10:45 AM
    Range 44
    Georgia
    2008 FJ TTE
    Thanks for the help, gonna just get a rear set of 5100's.
