Rear shock question.
Discussion in 'Suspension' started by Woodsbum, May 7, 2016.
  1. May 7, 2016 at 5:00 AM
    Woodsbum
    Woodsbum [OP] Member
    07Tacoma TRD Sport
    None
    My 07Taco needs rear shocks. Its my every day driver but will be pulling a 4400# camper. Any suggestions on what to use? Any input will be greatly appreciated, thanks.
    bigmw likes this.
  2. May 7, 2016 at 7:33 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Bilstein 5100 but the springs may need help so consider Ride Rite air bags. Firmness and ride height adjustable with a puff of air added or removed.
  3. May 7, 2016 at 4:59 PM
    Woodsbum
    07Tacoma TRD Sport
    None
    Thank you. This is what I had suspected, just needed confirmation.
  4. May 7, 2016 at 9:31 PM
    David K
    OK, remember it is the springs, not the shocks that control things like ride firmness, height, etc. The shocks control the speed of the spring action so the truck remains under better control and doesn't bounce so much.
    bigmw likes this.
  5. May 8, 2016 at 4:55 AM
    Woodsbum
    07Tacoma TRD Sport
    None
    Had the frame and rear spring recalls to deal with when I bought the truck. Both were done, so pretty confident with the springs.
    Also looking at the Timbren ses setups.I've used this set up before in a work application.
    Thanks again David K.
  6. May 8, 2016 at 5:03 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I put on SumoSprings on my truck to deal with added weight, topper + gear. They work great, picked the rear up a 1/2 ". ride is a tad stiffer, love them. $180 @ Amazon.
  7. May 8, 2016 at 6:43 AM
    Woodsbum
    07Tacoma TRD Sport
    None
    Thank you jw, hadn't thought of Amazon,
  8. May 8, 2016 at 8:47 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I agree with David.....HI DAVID !!...:wave:
  9. May 8, 2016 at 8:52 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Eh.. Buy some new Bilstein 4600s from someone on here for $50 and then spend $400 on airbags and cradles.
    5100s would be more than you need to spend and no advantage in your situation unless you're lifted.
    Mush Mouse likes this.
  10. May 8, 2016 at 8:56 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Jeezus this question has been asked & answered like a trillion times...you just a post whore...
    :p:D
    gregzz likes this.
  11. May 8, 2016 at 9:01 PM
    T4RFTMFW
  12. May 9, 2016 at 2:04 PM
    Woodsbum
    07Tacoma TRD Sport
    None
    Sooo maybe I should seek answers elsewhere?
    gregzz likes this.
  13. May 9, 2016 at 2:07 PM
    T4RFTMFW
    Are you lifted?
  14. May 9, 2016 at 2:08 PM
    Woodsbum
    07Tacoma TRD Sport
    None
    Negative. Stock height.
  15. May 9, 2016 at 2:15 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    what he said, no lift Bilstein 4600s Heavy Duty FTW
    T4RFTMFW[QUOTED] likes this.
  16. May 9, 2016 at 2:20 PM
    T4RFTMFW
    Then don't get 5100s. Go 4600s for 1/4 the price and get some airbags to restore your rear height while under load.
  17. May 9, 2016 at 2:22 PM
    T4RFTMFW
  18. May 9, 2016 at 4:20 PM
    Woodsbum
    07Tacoma TRD Sport
    None
    Thanks.
  19. May 9, 2016 at 5:14 PM
    David K
    Both my Bilstein stock "heavy duty" shocks (standard for TRD Off Road Tacomas) were leaking and one was totally shot after 6 years and 80,000 miles. The 5100s are BIGGER, stronger, yet still very cheap shocks. You will be "lifted" once you install the RideRite air bags and put in more than 10 psi... at 30-40 (max for me) your unloaded truck will go up 3 inches in back. The air bags max is 100 psi... but NEVER go that much... 35-40 psi should level you or even raise you with a maximum load in the truck.
  20. May 9, 2016 at 5:28 PM
    T4RFTMFW
    Don't be silly. There are countless Tacoma's running stock 4600 shocks and airbags, airbags are not for lift - they're for restoring ride height under load. Nobody who isn't cruising Tacoma forums cares nothing about 5100s, 90% of Joe Public buys the same replacement shocks or buys a similar shock from their auto parts house of choice. People who tow and haul get what they need. Hundreds of thousands of farm and ranch trucks run airbags and are otherwise completely stock! To say you can't run them with airbags is total nonsense.
    5100s and 4600s are identically internally and identically valved, so they will perform no worse or better than the other on a stock height truck. This is proven, not an opinion. Both shocks are basic, mid grade shocks. 5100s are a magic bean on this forum, for no reason other than everybody thinks they're the best shit ever. They aren't!
    You say your shock leaked. Have you ever searched for leaking 5100 threads on this forum or other? Some guys have leaks under 10k miles, it's not even what I would call unheard of.
    6 years and 80k miles on a pair of cheap shocks is a pretty good life. Your experience with a single set of shocks doesn't change the design specs or opposite realities of either shock.
